» Online Users: 423
1 members and 422 guests
Heist
Go Back   DCSportbikes.net > Sportbike Forums > DC, MD, VA Sportbike Chat
Intermittent starting - 2016 Kawi Versys 650 LT
I hate Hybrid drivers
david636's Avatar
Intermittent starting - 2016 Kawi Versys 650 LT - May 19, 2017, 02:13 PM
Good day gents,
I have a 2016 Kawi Versys 650LT. I call it my old man bike.
When it sits for a couple days it doesn't want to start. The first time it did it was last Monday right when I wanted to go to work. I thought it was the spark plugs since it had 10,000 miles on it. I changed them real quick and it didn't start immediately. I had to cycle the key a few times, then it started no problem. I dismissed this as air bubble in the pressurized fuel system. Once started it runs well. And tends to start back up after sitting between 10 seconds to 8 hours.
I worked from home Wed and Thursday and I go try to start it this morning. The fuel pump primes, but won't start. It turns over but doesn't fire. I cycled the key a couple times and on the 4th time it started. Ran fine to work. I expect it to start this evening so I can go home.
It's under warranty until April so what could be causing this? There is no reason to drop it off at the dealer until I can duplicate the problem on purpose in my opinion. I'm thinking electrical firing issue. What would cause it to be intermittent based on not riding it for a couple days.
Triumph-ant
Sal_the_man's Avatar
May 19, 2017, 04:06 PM
Test the starter solenoid. Had the same issue twice on the daytona and it was the culprit
1996 GS500E - Sold
2001 Speed Triple 955i - Sold
1999 Daytona 955i - Sold
2000 Ducati 748S
david636's Avatar
May 19, 2017, 04:30 PM
Doesn't the starter solenoid just make the starter turn? The engine turns over but doesn't start.
Triumph-ant
May 19, 2017, 06:57 PM
You're right I misread that
1996 GS500E - Sold
2000 Ducati 748S
Slowest Going Straight
SailorJack's Avatar
May 20, 2017, 06:34 AM
I had a similar issue with the ninja 1000 I owned a few years ago. I got over it by just blipping the throttle when pressing the starter. It seemed to be not getting enough fuel when first starting after sitting but my Ninja did this every time regardless of how long it was off for. Your versus sounds like it may be something more.
MSF Rider Coach 166210
Your Ad Here
Heist's Avatar
May 20, 2017, 07:48 AM
I'd spend exactly no seconds of additional time continuing to try to diagnose this. It's under warranty - you paid for someone else to spend their time troubleshooting.
Record each start-up until the problem happens.
That video will be sent to the dealer service tech to show them it's not a phantom problem, and inform them the best chance of duplication is by leaving the bike alone for >10 hours before trying to start it.
david636's Avatar
May 22, 2017, 03:00 PM
I need to record a start process. I meant to do that this morning. I'm not a fan of people touching my bike. Since it's my daily rider I don't want it sitting at the dealer for weeks while someone waits for motivation to figure out the problem.
What is a chicken strip?
vtwinjunkie's Avatar
June 27, 2017, 07:46 AM
so did you figure out what it was?
if not, what is the cranking voltage vs batt at rest?
how long has this been happening? my next guess is bad gas.
ps..you have my phone number...
My Chicken eats Busa's
June 30, 2017, 07:57 AM
Bring it to Brooks Cycles and you won't have that problem.
....just sayin'
2003 Honda SuperHawk
Click here for Brooks Cycles!
david636's Avatar
March 9, 2018, 01:16 PM
This problem went away for a while but recently happened a few more times. This morning it wouldn't start after 5 or 6 times of trying to start it. The engine turns over, it just doesn't spark I imagine. I put it in gear, pulled in the clutch and it started right up.
It's something electrical. Something isn't communicating with something else. The warranty on the bike runs out next month when it turns 2 years old. 22,000+ miles of mostly trouble free riding.
Leoallafila's Avatar
March 9, 2018, 04:01 PM
Does it have a side-stand or clutch switch that need to be reading a certain position to allow for the engine to start?
2006 BMW R1200ST
2003 BMW K1200GT (current)
2004 Ducati 998s Final Edition (current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
david636's Avatar
March 9, 2018, 04:09 PM
I'm not sure but I have put the side stand up and tried with no change. The in gear clutch start today was a difference, not sure if it was just an anomaly or if there is legitness to it. More tests needed I guess. I have also put it in gear and bumped it a little to change the position of the crank, no change either.
March 10, 2018, 02:54 AM
You can visually look for the microswitch in the clutch mechanism, most times it's somewhere close to where the lever pivots, often on the lower part of the assembly. You should hear it click too if you just move the lever some MM away from it's resting point. The easiest test would be to dowse it in WD40 and operate it a bunch of times to let it penetrate, and see if that changes the behaviour. Same thing about the switch on the side-stand. They often get covered in chain grease and grime.
If you determine it's one of those guys you can always bridge it and forgeddabouit until you get a new switch.
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
March 15, 2018, 11:56 PM
pull the lever all the way in, and snap it back out a few times to give the switch a pop. see if this gets the switch to work properly. seen it a bunch on budget bikes. or. just tape the leads together. you aren't a child, you don't need the switch.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
