» Online Users: 471
4 members and 467 guests
2blueyam, Heist, Slider, superchickencornermonster
Most users ever online was 4,519, September 2, 2015 at 04:26 AM.
Go Back   DCSportbikes.net > Sportbike Forums > DC, MD, VA Sportbike Chat
Valve Adjustment
Triumph-ant
Sal_the_man's Avatar
Valve Adjustment - April 20, 2017, 10:23 PM
Tackling the valve adjustment this weekend. Seems laborious, but hey it's something new to learn.
Anyone on here have a 25mm shim kit I could borrow? I'll pay for each shim if I need to use them. It'll be a pain to measure all the shims then go to the shop, then back home, etc. Lots of back and forth.
I needed to buy a $60 tool that allows me not to remove the cams. But the latter may be the better option...ugh
1996 GS500E - Sold
2001 Speed Triple 955i - Sold
1999 Daytona 955i - Sold
Triumph-ant
April 25, 2017, 02:27 PM
What a PITA. Took me 12 hours total. The valve adjustment itself wasn't too bad just required a precise eye and hand. Putting the valve cover and gasket back in took me 3 hours...such a confined space. I was raging but thankfully got the job done.
Exhaust valves were in spec but all the intake valves were nearly shut - .02mm gauge wouldn't fit. Explained the hard cold starts. Now it happily cranks up.
The numbers
"Now me and the mad scientist gotta rip apart the block and replace the piston rings you fried"
Yum
Clumsy tool
1996 GS500E - Sold
Leoallafila's Avatar
April 25, 2017, 02:35 PM
Nicely done!!
Wait, what happened to your piston rings????
2006 BMW R1200ST
2003 BMW K1200GT (current)
2004 Ducati 998s Final Edition (current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
shiphteey's Avatar
April 25, 2017, 03:17 PM
All good it happens. I just burned up #4....its part of the game.
www.GeminiMotorcycles.com
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
beatle's Avatar
April 25, 2017, 05:36 PM
Makes me glad I took my bike to Brooks. F that.
Do you know if your valves were in spec @ 12k?
Triumph-ant
April 25, 2017, 06:00 PM
Originally Posted by Leoallafila View Post
Nicely done!!
Thanks.
And it's a reference to F&F @ 1:00
Ouch. Will you be re-machining the head?
I bought it with 14K and no service records. I'll assume no considering how far out of spec they were.
You have a street triple right? Your valvetrain is shim under bucket so they are less prone to going out of spec. However, you have to pull the cams to replace one if needed. It's more work but expedites shim swapping.
1996 GS500E - Sold
beatle's Avatar
April 25, 2017, 07:48 PM
Yes, a couple of Triples. I swapped to Daytona cams at the same time I had the valves checked on my 08. I'll probably do the same on my 2010 if it makes it to 12k.
My FZ6 called for 24k miles between valve checks and most people find the valves to be in spec. One guy went all the way to 77k without checking them. At that time only 2 exhaust valves were out of spec. What a great bike that was.
Triumph-ant
April 25, 2017, 09:17 PM
Must be fast. Hopefully not faster than mine!
That's awesome. I know the FZ1s have a service interval of 25K and they rarely go out of spec as well. It's certainly a deciding factor when you lay down some miles.
1996 GS500E - Sold
April 25, 2017, 10:35 PM
You don't know fun til doing the valves on a V-4. I'm in the middle of checking the valves on my street one. I did the race bike last summer during the complete rebuild. One thing this bike has going for it vs a VFR is the ability to use a special tool to hold the cam sprockets in place and unbolt the shafts if they need to be removed. The race bike only had a few valves out of spec.
I won't be surprised if I find a bunch out of spec on the street bike. It's always been hard starting and not as smooth. Hopefully I can get it done without removing the throttle bodies too.
Triumph-ant
April 25, 2017, 11:27 PM
No kidding. Ive read the RSV4's clearances go out of spec often as well.
1996 GS500E - Sold
Slow as a turtle...
maverickfhs's Avatar
April 26, 2017, 09:40 AM
While we are at it, by any chance did you ever adjusted VFR valves or found them out of spec at some particular mileage?
Thank you
shiphteey's Avatar
April 26, 2017, 11:32 AM
I figure the motor was bound to go sooner or later. It is the original motor back in the bike ... about 40ish K...and a bad 2nd gear to boot. WOT in 6th I realized I couldn't pull to the rev limiter ... and it was getting noisy so she puked 4th...it was bound to happen and the motor was removed from the bike for a reason. Compression tests showed 2 and 3 weren't exactly stout.
So I'm left with 2 motors.
The motor from the crash had 20ish K....I'm presuming the top end and trans is still good. We know from trying to restart it post crash that it has horrible knock so bottom end is toast.
This 40k motor has a bad 2nd...and I know top end is trashed....
So if the starts allign....I can use the 40k rods/crank with the 20k head/cyl and trans....who knows.
636 motors ain't cheap the sprint/dwarf car guys use em and keeps the prices high. My line in the sand is $1000 for a good one.
Not looking to do upgrades to the motor till the season ends...time & money...
A.
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
shiphteey's Avatar
April 26, 2017, 11:34 AM
My first time trying to do a valve adjustment by myself took 8 hours on a Ninja 250...didn't help that my tools were rusted from the salt flats and I had to hold the sockets in place because the ratcheting mechanism was messed up....with oily fingers....PITA.
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
Triumph-ant
April 26, 2017, 10:46 PM
Wow those motors are expensive. I'm seeing close to $1900 for some!
That's a predicament you're in. With those prices I'd keep an eye out for crashed bikes as well. Mixing the block and head could work, it'll just require time.
1996 GS500E - Sold
shiphteey's Avatar
April 27, 2017, 07:26 AM
I have too many motors and motor parts everywhere it gets clusterfuckish so if I can rebuild it'll help with the clutter.
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
