» Online Users: 582
2 members and 580 guests
beatle, Sal_the_man
'04 R6 misfiring on full throttle at 12k-> rpm???
Tempting Fate
demitriusr6's Avatar
'04 R6 misfiring on full throttle at 12k-> rpm??? - August 30, 2006, 09:17 AM
Trying to figure out what is going on with my '04 R6. It's misfiring/hesitation when I'm on full throttle after it gets up too about 12.5K rpm.
It's happened in 2nd and 3rd gear so it's not the 2nd gear issue with the R6's.
Any ideas? If I roll through the RPM's on anything other than full throttle, I can go up to 14K rpm with no hesitation.
Is it a ECU issue? Just really weird it's only on full throttle.
Thanks for the ideas.
Track Ho
r6hokie's Avatar
August 30, 2006, 09:18 AM
check your spark plugs
August 30, 2006, 09:19 AM
mods?
2016 Concours 1400
August 30, 2006, 09:34 AM
+1 and add in the air filter as well!
If you have a power commander make sure you have the correct map programmed as well.
give us more info on the bike along with any history of crashes or problems.
riding history, mods, mileage, service intervals, etc...etc...
Tempting Fate
August 30, 2006, 10:09 AM
Update - No performance MODS
Crashes - never downed/crashed.
Miles - 9,500
Last Service - 4 months ago, had it prepped for the riding season, plugs, oil/oil filter/new tires, etc.
I ride her hard and often get her up to 14k rpm or ride her between 10-12rpm for extended periods of time.
Need to get the oil changed but doubt that's causing the problem.
Thanks for the help!
August 30, 2006, 10:14 AM
Check the plugs and or change them along with the air filter.
Riding is like Sex. WEEE!
Rossi's Avatar
August 30, 2006, 11:13 AM
that could be anything.
IT could be the ECU, Plugs, fuel injectors.
Does an error code show up after it misfires?
I think it is the ECU.
"Riding a race bike is an art - a thing that you do because you feel something inside."
"I don't like being famous - it is like a prison. And driving for Ferrari would make it far worse."
"I race to win. If I am on the bike or in a car it will always be the same."
"I'm Valentino Rossi. And I want to be a person, not an icon."
  Send a message via AIM to Send a message via Yahoo to Rossi Send a message via AIM to Rossi Send a message via Skype™ to Rossi
Tempting Fate
August 30, 2006, 11:21 AM
No codes or anything on the display.
Finally got a spot to take in at Fast Lane Cycles in Chantilly. Tried Champion in Sterling/Herndon but they are working with a part time mechanic. I guess their main one was driving in from Winchester everyday and couldn't handle it anymore. Champion has an agreement with Fast Lane to handle the overflow.
Loudon Motorsports is booked for about a month but I really like that shop.
TEAM.SUKUZI
iceblizzxdc's Avatar
August 30, 2006, 01:48 PM
thats why I dont ride Yamaha's...
August 30, 2006, 01:54 PM
Yamaha's are one of the most reliable bikes out there...go to any race weekend and the majority of the bikes are Yamaha's.
Or is it that you don't ride Yamaha's because you prefer Suzuki???
BTW...I own and ride a Suzuki and also ride/race Yamaha's as well...
Track Ho
r6hokie's Avatar
August 30, 2006, 02:32 PM
I would bet money it is one of the four following
spark plugs(not put in right or not gapped right)
coils(common problem in the 03's but I had one start to go bad at around 18k in my '04)
recitifer(more common in the 99-02's)
throttle position sensor (tps)
all are easy fixes, look on r6messagenet too, let us know how it goes if you take it to that shop
Tempting Fate
August 30, 2006, 02:40 PM
Thanks for all those who replied. I got more responses on here then on R6messagenet.
August 30, 2006, 02:44 PM
I could be way off but what about valve adjustment? If you run your bike at 12K rpm on up for an extended period of time I would imagine that you'd need to get your valves adjusted...long shot but something to consider.
But your problem sounds like "spark" or timing so no codes tells me the ECU should be ok...enough people have R6's that you should be able to swap an ECU out.
As R6hokie said...plugs and coils would be good ones to check as well.
THE PATIENT
1hander's Avatar
August 30, 2006, 07:33 PM
sounds like a plug or bad coil---coils
  Send a message via AIM to Send a message via Yahoo to 1hander
