» Online Users: 508
6 members and 502 guests
2blueyam, Diggy, dubplaya, legendindisguise, Sal_the_man, tonetone
DJMiniMe's Avatar
April 30, 2003, 01:59 PM
I have a 1990 Kawasaki Ninja ZX-6D. The problem I have been running into is this. When I try to start the bike, it clicks but won't start. Is it the starter going bad, bad alternator, or is there more to it than that? Any help would be greatly appreciated. The battery is fully charged. Usually happens after it rains.
Thanks for your help.
  Facebook Page Send a message via AIM to Send a message via Yahoo to DJMiniMe Send a message via AIM to DJMiniMe
Twiggy6's Avatar
April 30, 2003, 02:02 PM
what makes you think the battery is fully charged? Do you have a Fluke or Voltmeter?
DJMiniMe's Avatar
April 30, 2003, 02:06 PM
I do have a Fluke Voltmeter. I have also taken the battery out and had it on a charger all night. It starts my room mates bike up without a problem when I put my battery in his bike to make sure that it is not the battery itself. I'm pretty sure it is fully charged. But then again, I can be wrong.
Twiggy6's Avatar
April 30, 2003, 02:15 PM
Does the battery show 12.6 volts with no load?
If so, check your connections and condition of all the wires to the starter.
Ward's Avatar
May 4, 2003, 05:19 PM
I think batteries can show full voltage and appear 'charged', but be sulfated? badly enough to where they can't provide enough current to turn the starter.
But, if you were able to start your buddy's bike, then it seems you have troubleshooted the battery already. The next step would be to bypass the starter relay, applying 12V directly to the starter motor. You might be able to pull the rubber boots back on the relay, and use a wire or screwdriver to short the relay's leads to each other. Or, run your own wires. Then if the starter turns, you know it's a connector or switch that's crapped up. Check the connections to make sure they are all good, then (try the starter switch or other switches exposed to the environment first.
-Ward
car54's Avatar
May 7, 2003, 07:55 PM
I'd be glad to check it out for you.. probably worn or dirty contact, solonoid, or brushes. All easy to fix.. I'll talk to you about it on monday.. we can check it out sometime if you want.
Matt
02 DRZ400
00 SV650s
08 Vino 125
  Facebook Page MySpace.com Page Send a message via AIM to Send a message via AIM to car54
