» Online Users: 547
4 members and 543 guests
Nobrains, Sal_the_man, scarab, tonetone
noise
static's Avatar
July 27, 2005, 12:55 PM
I've searched and came up with upgrades but, what about when to replace them?
How does one know when to replace rotors?
What to look for?
I just got the EBC HH pads put on because the stock units were low about 10% left.
I've got 25k on the bike with the recent pad replacement.
Eventually, I'd like to upgrade to better rotors for the rigors of track use but for now I would like to get comfy and proficient with the recent pads.
Btw, I already have SS lines which were great but with these new pads....WOW!
I don't get shimmies, braking is consistently strong and smooth.
Too Fat To Be Fast
BurnCycle's Avatar
July 27, 2005, 01:21 PM
I'm going to use OEM Suzuki rotors as an example...
The minimum thickness should be imprinted somewhere on the carrier. Suzuki uses "MIN.TH. 4.5mm" to signify what the minimum thickness should be (4.5mm). If it is less than that then they should be replaced. Normal rotor thickness is ~5.0mm
If the rotor is warped then of course itís going to need replacing. A vibration in the brake lever is a definite sign of a warped rotor.
Cheers,
Bern
13 Ducati 1199
06 Ducati PS1000LE
  Send a message via AIM to Send a message via AIM to BurnCycle
Diddle e i
Mocaba's Avatar
July 27, 2005, 03:23 PM
I hadn't thought of that but it's a good question. Thanks for the info Burncycle..
~ John ~
Experience is a hard teacher because she gives the test first, and the lesson afterwards
  Send a message via AIM to Send a message via ICQ to Mocaba Send a message via Yahoo to Mocaba Send a message via AIM to Mocaba Send a message via MSN to Mocaba Send a message via Skype™ to Mocaba
