» Online Users: 242
2 members and 240 guests
GRN96WS6, Sal_the_man
Brake Pads need replacing?
Spectroscopist/adventurer
fireclown's Avatar
Brake Pads need replacing? - August 19, 2006, 10:53 AM
I am getting a subtle scraping noise in my back brake. It only has 8000 miles on it TOTAL. Is this a reasonable amount of time for the pads to go? THe other symptom is that when I was lubing m chain this AM and hand turning the wheel I could hear a scrape. Could it be that the calipers are too tight? Or could the disk be warped?
Is this part of a major servicing, in general? I've had a few of these little problems, and I'm thinking of taking it in for a good once over. And how much should a major servicing cost? I'm in sort of a one horse town out here, and I don't want to get screwed.
August 19, 2006, 04:19 PM
do u ride hard and do u use the rear brake alot. I brake hard and i use the rear alot and I have about 3200 miles on my bike and the rear brake usually goes around 1o,ooo miles. most people when they use there rear brakes wll last anywhere from 15,000-17,000 miles. if your sliding the bike wih the rear brake it'll go probably around 10,000. ask the "jeeper"he races he should know.
August 19, 2006, 05:50 PM
brake drag is normal. You can usually snap off the inspection cover and look directly at the pad. 2/32nds is a good replacement point.
2016 Concours 1400
