» Online Users: 530
8 members and 522 guests
KneeDragr's Avatar
March 1, 2004, 10:03 AM
Seems like the case with all 3 guys I rode with this weekend that our tires looked significantly worse after Sundays ride. Didnt ride very far, to 211 and back. They looked bad enough that all of us swore not to ride at a brisk pace again before getting new tires.
They didnt look bad before leaving, and the pressures were fine. Could the months of inactivity degraded the rubber somewhat?
OneFunR6's Avatar
March 1, 2004, 10:43 AM
All tires have waxes, oils and other chemicals mixed into the rubber to improve the grip and handling properties of the tires. In motorcycle tires these additives are designed to be very temperature sensitive, hence the use of tire-warmers on race tires, which are designed to operate at much higher temps than street tires. All tires are subject to the loss of these additives due to "heat cycling". In the "olden days", before the advent of specialty tires, some cycle shops would put new tires up on the roof during the summer to "heat cycle" the tires w/o any tread wear. These were then asked for and sold as the 1st "touring" tires. The heat cycling process is also known as "out-gassing", as the additives will "out-gass" b/c of the heating of the tire and the centrifugal force of riding on them. This is the main reason that track tires are actually worse on the street than street tires, b/c race tires rarely get as hot as intended for performance and are not designed for more than a few heat cycles, and thus quickly loose their stickier 'advantage' [if they even have one at street speeds, as tires cool off very quickly] after just a few (10-20+) heat cycles. Tires that sit, particularly those that are inflated, can have this out-gassing problem, too, due to temp changes during long term storage and the air pressure pushing on the rubber from the inside. This may be one reason for the sudden tire wear. Most cycle tire manufactures will not ship tires to the shops after they have been sitting for a certain time period. Hope this helps.
ps, I am not making this up! lol! I have a friend w/a PhD. in chemistry who works for Michillen.
“To announce that there must be no criticism of the president,
or that we are to stand by the president right or wrong, is not
only unpatriotic and servile, but is morally treasonable to the
American public.” -Theodore Roosevelt
  Send a message via AIM to Send a message via AIM to OneFunR6
ThrustinJZX6's Avatar
March 1, 2004, 11:11 AM
...in other words, yes.
I rode a good ride with Steve and BamBam. When I go home I noticed that there was significant pilling on the rear tire that i've never seen before...now that may have been bacause I was trying wheelies all day...or it could have been because of these out-gasing temperature changes.
Anything that sits degrades, but it's nothing out of the ordinary. Also, don't put anything on your tires off-season.
March 1, 2004, 12:19 PM
Thank you, there is no way im reading a long post by that guy.
March 1, 2004, 12:38 PM
It hurt my head.
OneFunR6's Avatar
March 1, 2004, 01:26 PM
March 1, 2004, 03:22 PM
Ozone is a major contributor to tire degradation.
I'm curious as to what type of tires are in question. I know of a certain tire that was on my bike while it was in the shop for 9 months (I was deployed for the last 7 of those months). When I got back to riding these tires were even crappier and wore very fast. I had these same tires on another bike once and found that the last .25" of useable (before wear indicators) rubber wears extremely fast.
I put the original (from new, but now with 3500 miles) tires back on and turned faster lap times than I had when the previously mentioned tires were new.
boxing twins
hayabusafiend's Avatar
March 1, 2004, 04:19 PM
Electric motors produce ozone. The larger the electric motor, the more ozone produced. So, keep the tires away from freezers and refrigerators (and heaters for that matter) in your garage.
-- Chris
BMW R1100s
KneeDragr's Avatar
March 1, 2004, 04:22 PM
As it turns out, all 3 of us are running Pirelli's.
2 running Supercorsa race compound, 1 running Diablo Corsas.
