» Online Users: 236
2 members and 234 guests
Sal_the_man, Triple X
September 7, 2005, 04:25 PM
04' gsxr 600 k4
I have half the work done already, just need a little help.
I have an error code -C28 which is the STVA(Secondary Throttle Valve Acuator). I need to check this thing but I don't know where it is.
Does anyone have a late model GSXR and know where this part is.
Please help me out gys and gals. I know it's got to be an easy fix.
Why should I pay the dealer $80.00 or more dollars for a 5 min. fix.
thanks guys.
One and Only
Cloaca's Avatar
September 7, 2005, 04:47 PM
The STVA is the large white plastic piece attached to the right side of your throttle body. It's located directly above the throttle position (TP) sensor, while the STP sensor is attached directly. It's big and white, you can't miss it.
Having said that, I would highly recommend you not remove it. But, do as you please. We probably don't know what we're talking about.
Read above.
Right up the 1 hole.
One and Only
Cloaca's Avatar
September 7, 2005, 04:54 PM
Since I'm in a good mood....
Chances are the actual problem isn't with the acuator itself, but rather one of the sensors attached or the connection. Check those before you go ripping the damn thing out.
That'll be $80, please.
September 8, 2005, 04:52 AM
I will check today and let you know.
If it works i'll pay your admission to
TOP DAWG M'C & DOTSON'S 8 TH ANNUAL FEST IN GLEN BURNIE MD IF YOU GO ( HOW ABOUT THAT).
THANKS GUYS.
September 9, 2005, 04:45 AM
Didn't work, gonna have to take it to the shop.
