» Online Users: 589
2 members and 587 guests
Cinko, Sal_the_man
General info about forks
ThrustinJZX6's Avatar
General info about forks - March 29, 2018, 09:30 AM
2000 Ninja ZX6R and I've only had a shop recommend replacing the seals once around 2004.
I put zip ties on the forks and I have never bottomed out the suspension, maybe two inches away from bottom. I've taken it to lots of track days and never had any issues with ride and feel and it handles great.
My question is how often should I have replaced the fork oil and at 220lbs, should I change the stock springs or get new ones due to age.
I've never put more than a couple hundred into this bike besides oil, tires, spark plugs, and a filter.
I think I'm willing to spend some on upgrades if necessary, but I'm more of the ain't broke don't fix it side of things. I don't mind doing work myself and I'm comfortable ripping the bike apart as long as I don't need hundreds of dollars of special tools.
Thanks for the advice!
'00 Kawasaki Ninja ZX6-R
'03 Honda XR100R
Xbox: ThrustinJ
March 29, 2018, 10:02 AM
From a personal standpoint, I've always serviced forks around the 20k mark for mileage. I probably wait too long. When I dump the old stuff it smells torched. When I ride it after doing the service is feels noticeably better.
Springs don't typically wear out. I'm of similar weight and have had good results with stock springs in some bikes and better results with springs more matched to my weight. Sometimes I don't like the aftermarket springs. If you are doing the service and work, I'd spring (ha!) for the springs matched for your weight and swap them out. If they aren't to your liking, you can swap them back and sell them.
2016 Concours 1400
March 29, 2018, 10:08 AM
Thanks!
'03 Honda XR100R
Xbox: ThrustinJ
Leoallafila's Avatar
March 29, 2018, 12:40 PM
I find that a proper suspension setup only comes into play when you start pushing a little. As long as they are not gone and the bike is bouncing around you're the limit, not the forks or the shock.
If it ain't broke, don't fix it....
2006 BMW R1200ST
2003 BMW K1200GT (Current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
March 29, 2018, 01:07 PM
After a few years of track riding, I feel like I like how much/how little play the bike has at the track. Any softer in the rear from full stiffness and I wheelie too much coming over the bridge hill and carousel at Shenandoah. When I wondered if the front was too soft, I thought to check it and it really does seem fine.
After 18 years, this bike still holds up and is amazing for me.
'03 Honda XR100R
Xbox: ThrustinJ
March 29, 2018, 02:37 PM
Suspension specialists will recommend changing the fork oil at least once a year. I honestly think that's a bit much unless you're a super quick rider around the track. I try to change it out every few years for a bike that sees track time. I'm much heavier though and aftermarket suspension is my only option.
That being said, if you haven't changed your fork oil in 14 years you definitely should.
Cause remember, you will adapt to the limitations of your machine and feel like it's fine but it could be much better.
Your Ad Here
Heist's Avatar
March 31, 2018, 06:57 PM
I like to do a general all-fluids flush every 2-3 years.
Fork Oil, Brake Fluid, Coolant.
If you're tracking it occasionally, reduce the service intervals to 1.5-2 years.
If you're tracking it often, every year.
Springs are not needed unless you feel you're weight and riding style is approaching the max of what the current spring rate can handle.
April 3, 2018, 07:59 AM
Its def time for an oil change, but you will need to recheck your set up and your suspension adjustments after.
Thanks,
Fast Lane Racing
CCS762ZX6's Avatar
April 3, 2018, 08:15 AM
dont forget to get your steering damper serviced as well.
April 3, 2018, 07:55 PM
Yes you should definitely have the forks and shock serviced. Also you need to soften up the front end some. I would bet you should have the bushings in both front and rear replaced.
shiphteey's Avatar
May 24, 2018, 03:41 PM
Dash in wrong spot bruh
www.GeminiMotorcycles.com
ZX14: 222 mph
ZX12: 229.6 mph
ZX10: 202.8 mph
ZX9: 177.6 mph
ZX6R: 180.8 mph
EX650: 130.7 mph
EX300: 114.7 mph
EX250: 122.4 mph
