» Online Users: 235
1 members and 234 guests
Triple X
Kawasaki Will Start But Not Idle
blueboxer's Avatar
Kawasaki Will Start But Not Idle - May 21, 2012, 08:31 AM
Please help a brother out before I sell this bike!
2007 ZX6R 7,500 miles
Issue: Bike will start but not idle. When I try to turn the throttle it shuts off.
I've been riding my bike fine for a few weeks. It was sitting outside all last week (remember when it was raining) under a cover. I went to ride it Friday and it would not stay on. I can start it and it idles really low. Then when I hit the throttle it immediately cuts off.
Prior to this incident, I put in a full tank of PREMIUM gas.
So I've been online this weekend trying to find a resolution. I can't find THE answer. I've drained the tank, put in new fuel with Seafoam. No luck. Air filter is fine. Checked fuel lines and they seem to be fine. Battery is 12 great volts!
Anyone have any recommendations?
Stand Collector
airjor13's Avatar
May 21, 2012, 08:36 AM
Have you tried messing with the idle control knob, I m not very familiar with ZX-6 but on most bikes its usually located somewhere near your left knee, above the shift linkage.
899 Panigale
LooseTooth's Avatar
May 21, 2012, 08:59 AM
I'd be looking at fuel delivery first. Fuel filter, pump, etc. TPS? Not so sure about that, but it might be worth researching if this is one of the symptoms.
If you think you may have had water in there, then you could still have some in your system. You can drain and refill the tank again to further dilute the water. Also you may have to let it idle a while and get the contaminated gas through the system.
I would suspect bad gas wouldn't give you a great idle though, so not so sure I would spend time on that possibility.
blueboxer's Avatar
May 21, 2012, 09:39 AM
Yea tried that. The knob isn't providing anymore idle.
People on other forums mention that water maybe in the tank, but after draining it and using seafoam, I just can't see that being the issue. I'm going to check the pump. Its wierd, the last day I rode the bike I filled up and rode from centreville to leesburg and back. When I went to drain the gas it was like I didn't use any gas. It was still topped off.
Mojito Anyone?
onel0wcubn's Avatar
May 21, 2012, 09:44 AM
check the servo motor
ay ya yay
Leoallafila's Avatar
May 21, 2012, 11:07 AM
Sounds like it's not getting enough fuel. Hard to tell from a distance but that is my guess unless you have a fault code light ("engine light") on.
2006 BMW R1200ST
2003 BMW K1200GT (Current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
May 21, 2012, 11:27 AM
I would take the tank off and start looking at rubber hoses and lines. Cracked or missing vacuum lines with cause idle issues for sure. How does it run depsite the idle? Have you tried the ol Italian tune up?
2016 Concours 1400
Stand Collector
airjor13's Avatar
May 21, 2012, 11:44 AM
Is that when you just redline the shit out of it? haha
899 Panigale
100% Kawasaki Biased
Thomas's Avatar
May 21, 2012, 11:54 AM
Have you checked the voltage from the stator/rectifier (should be ok if your battery is staying charged) and the coils/plugs/connections to make sure they are clean, undamaged and tight? I had build up on a plug once that just needed a brushing and it was fine. I assume you pluged in the fuel pump power feed between draining and refilling the tank. These things are almost always an issue of fuel or spark.
You can live in your car, but you can't race your house.
'07 ZX-10R - 156 RWHP/182 MPH
'09 KX450F - VCHSS 29F
'85 ZL-900 Eliminator
'01 Ninja 250 (Sold)
'06 636 (Sold)
'99 ZX-6R (Sold)
'94 Ninja 250 (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htmfeature=related
The difference between men and boys is that boys make excuses and men make changes.
Ni Hao Ma, Bitches!
lemond's Avatar
May 21, 2012, 12:00 PM
check your fuel lines again, make sure they are not pinched.
2006 Husqvarna 510sm
2006 Honda 919
1995 Ducati MOnster 900 - sold
2000 Suzuki GSXR 600 Track Bike - sold
  Send a message via AIM to Send a message via Yahoo to lemond Send a message via AIM to lemond Send a message via MSN to lemond
May 21, 2012, 01:24 PM
Install new spark plugs and you'll be fine. You have one or two that have fuel fouled so when it starts the RPMs are low because the fouled plugs are not firing and when you hit the throttle the fuel deliver is increased and you are still without 1-2 cylinders so it dies. Well that's my EDUCATED guess anyways.
Taladis's Avatar
May 21, 2012, 01:38 PM
+1, just from my LIMITED experience, it sounds like this. Sounds like a similar issue ive seen in a car, replaced the spark plugs and worked fine.
TheGreenWeenie's Avatar
May 21, 2012, 01:51 PM
What's the usual lifetime of spark plugs anyway?
Sent from my iPhone using Forum Runner
2007 ZX-6R
Joshua
Thomas's Avatar
May 21, 2012, 01:54 PM
I think the book says every 7500 miles, but that is a little crazy. I changed mine at 15K when I did my valve check and they looked fine. How often you clean your filter is a major factor too.
'06 636 (Sold)
'99 ZX-6R (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
May 21, 2012, 02:39 PM
15-20k usually for plugs. Just check them.
2016 Concours 1400
