» Online Users: 542
3 members and 539 guests
2blueyam, amit, CCS762ZX6
Little help? Rebuild forks. Older Honda CB's
Largely Unsupervised....
Corbett's Avatar
Little help? Rebuild forks. Older Honda CB's - November 2, 2007, 01:28 PM
Anyone have experience with rebuilding forks on older Hondas. I've got a '82 CB750F and just acquired a '83 CB1100F that both have leaking fork seals. I'm somewhat capable, but have not done it before. I would appreciate help/supervision from someone with practical experience that would supplement instructions from a clymer's manual or "how-to" website. Generally, If I see it done once - I can do it again. I'm in Tysons Corner, and have a garage, but could trailer the bikes if I had to.
This has been another fine contribution from Captain Craptastic.
2014 Harley Street Glide
'08 Brass Balls Bobber
'04 KTM 625 SMC
'78 Honda CB750K (soon to be mated to sidecar)
'07 SSR 125
'99 BMW K1200RS (SOLD)
'95 Honda Z50R (donated to a buddy)
'89 CR500R (SOLD)
'83 Honda CB1100F (SOLD)
'82 Honda CB750F (SOLD)
Dressed for Success
Ninja636's Avatar
November 2, 2007, 01:43 PM
I just did this the first (and second time) on some dirt bikes. I couldn't believe how easy it really was. Here's a good guide on inverted forks which may or may not help much since your's are probably standard: http://www.mxboards.com/forums/viewtopic.php?f=6&t=20
Banned!
November 2, 2007, 01:54 PM
after you drain all the fluids (bolt on bottom, or cap on top)
1. take out outer dust seal
2. take out C clip that is under the dust seal
3. have a friend hold one end, and you hold the other.
4. compress and pull (like tug a war) hard, one yank at a time.
5. it will come apart.
6. take all pins out that hold the seals in.
7. install new seal
8. put back in and use a manual press to put the seal into place. (looks like a metal tube that you bang down to put the seals in.
9. install c clip and dust seal...try to replace this.
use oil level gauge to put at right level...
total time 1` hour for both.
Corbett's Avatar
November 2, 2007, 02:04 PM
Excellent link Ninja636!
Still require supervision......
'04 KTM 625 SMC
'07 SSR 125
'89 CR500R (SOLD)
