» Online Users: 614
2 members and 612 guests
gixxer123, GRN96WS6
Mechanical Help - Advice after Oil Change
Gone with the wind....
Sassygurl's Avatar
Mechanical Help - Advice after Oil Change - May 7, 2011, 04:16 PM
I'll describe the issue as best as I can....any advice would be helpful. So I took my bike to get the oil changed and have the fluids checked. Itís my 1st oil change so riding difference may be normal but I don't know.
On the ride back home I noticed:
1) The bike (Kawi Ninja 650)seemed to be making a humming and sort of vibration noise up in the area of the ignition and speedometer.
2) Itís not as easy to take off in first or shift to 2nd anymore. I had to roll on the throttle harder for some reason. The bike seemed to rev faster making me think I need to shift sooner than usual too.
3) There is a slight squeak when I brake, which I hear sporadically. This was there before but its louder now.
EDIT***I guess I should add they replaced my right fairing and put a new brake pedal on. The brake pedal seems fine.
Kawi Ninja 650R and ZX6r
Ride In Paradise Tree and Mz Nez
50th anni
F3_Chimp's Avatar
May 7, 2011, 04:17 PM
what kind of oil was in it before, and what kind of oil did they replace it with?
...And Boom Goes the Dynamite!
cbr f3= sold
636= gone
r6= sold
cbr 1k= sold
vino 125= stolen
zuma= yutt uggh
GDMFSOB
The Evil Twin's Avatar
May 7, 2011, 04:29 PM
1: When you hear the vibration, grab your key. Of course be careful not to turn it off, but sometimes the key vibrates in the ignition and makes noise. I know mine does.
2: Wet clutches are often affected by the type of oil that is used. Syn or traditional, base stock, weight, etc. can all affect how your clutch (and transmission) act.
I would assume that you took it somewhere that works on bikes, and did not just dump some generic energy conserving oil in it. If in doubt, no harm in contacting them. Most shops would rather have a customer ask instead of having a bad feeling about them.
#132 EX
2015 MARRC Crash & Burn Award
Don't ask me,I'm Canadian
C2H5OH's Avatar
May 7, 2011, 04:35 PM
My two cents.Take it with a grain of salt...
May all just be in your head.I always think something screwy is going on...
"What the heck is that jingling? Must be a screw loose in my forks.They're gonna fall off and I'm gonna do the Superman.Oh wait,it's just my 14 keys vibrating"
"Bike is going side to side.Must be a flat tire and I'm going to do the Superman.Oh wait,I have a mohawk on my helmet and I'm behind a truck and my head is going side to side"
"Bike is revving out of control.Must be a bad clutch.Oh wait,I shifted into neutral and gunned it.Still gonna do the Superman"
Can't remember when I had a new bike,but you may be past the break-in period and it's just the way of mechanical things.
GDMFSOB
May 7, 2011, 04:40 PM
^^ That is the most likely. Good thinking there!
Even when I do my own work, I "notice" something different.
#132 EX
Sassygurl's Avatar
May 7, 2011, 04:51 PM
I took the bike to Colemans and by the time I could call they closed and won't be open again until Monday. I purchased the bike used, so its past the break in point unless there is one after each service. Not sure what oil was in there previously or what kind of oil was used today. I'll call on Monday and find out.
I don't think its in my head.LOL I pulled onto the highway to turn left and realized the damn thing wasn't moving by just rolling on the throttle a little like I usually do. Kind of scared me. Will check the key for vibrations when I go out again.
cake > pie
absinthe_now's Avatar
May 7, 2011, 04:59 PM
Check your lever. May just need a little WD-40. My clutch lever was doing it a few days ago. I couldn't really tell where it was coming from at first with my helmet on. Like C2H5OH I blew problem out of proportion in my head and went immediately to worst case senario and though my clutch was fucked in some way. Kaneda zeroed in on the problem while waiting for others before the Lima event and a little WD-40 when I got home and quiet as a mouse now.
50th anni
F3_Chimp's Avatar
May 7, 2011, 05:03 PM
did they put new brake pads on your bike?
cbr f3= sold
636= gone
r6= sold
cbr 1k= sold
vino 125= stolen
zuma= yutt uggh
May 7, 2011, 06:46 PM
+1 on the oil and WD-40.
Its possible its just the new oil. Synthetic is a big difference than reg oil depending what you had in there prior to. WD-40 on the lever is a good look if its not the brake pads. Make sure the fairing tight. PM you
Sassygurl's Avatar
May 7, 2011, 07:25 PM
I'll try the WD-40 and see how it does throughout the week.
No, I thought maybe she needed some, which is why I asked for them to do a check over. Brake pads weren't recommended though.
Checked the fairng and made sure it was tight, Thanks...will call him Monday.
May 7, 2011, 11:36 PM
What kind of oil was in your bike before? If they put mineral based oil after having synthetic in there you may feel quiet a bit of difference with a wet clutch. I think the rest of it is in your head as some have mentioned. Some of the issues you mentioned were probably there. You just became uber sensitive to all the little noises post service.
Sassygurl's Avatar
May 8, 2011, 07:29 AM
I had my brother come over today and check the bike out. He held a few things while riding. Apparently, the vibration noise is coming from the windscreen. The fairing which was replaced is slightly loose.
I guess the issue with taking off came from having the oil changed and possibly a wet clutch. He said it shifted fine even starting out at 2000 rpms, so maybe it was the new oil.
I sprayed some WD-40 on the lever as suggested. If that doesn't help, I'll try spraying the brakes as someone suggested on another forum.
Thanks everyone!
I've heard this a lot across the forums. LOL Yes, I probably did become more sensitive after the oil change.
May 31, 2013, 09:02 PM
coleman. ugh. I would take it back if it isnt making any power
May 31, 2013, 09:08 PM
Thanks everyone!
Wait, wat? Spray the brakes with what? I can't think of anything you want to ever spray on brakes. Seriously, I don't know what someone told you but that sounds like a recipe for disaster.
TheGreenWeenie's Avatar
May 31, 2013, 09:32 PM
Never a truer statement made. It seems like anything that changes in just the slightest becomes the most horrifying thing ever.
Luckily for me when i started to hear some weird clicking sound when I braked I didn't just blow it off. Turns out my upper folk holder has a crack in it.
2007 ZX-6R
Joshua
