» Online Users: 557
5 members and 552 guests
Need Help Diagnosing Problem
Need Help Diagnosing Problem - September 2, 2009, 11:49 PM
Alright, so I'll tell you what I did and then include the issues I'm seeing. *
My bike died after leaving the lights on all night. *I took the seat off the next morning (late for work) and couldn't find the battery. *It was under the ECM (which is the black box thing with the two 20-some-odd pin connectors coming out of it), but I was sweating, hungover, and didn't look at it carefully. *I saw the red covered metal connection (which I found out later I think is the ignition switch, you can see this where I designated the '+' connection on the pictures because that's where I connected the positive lead from the car battery). *I connected the negative lead to the placer where i have the '-' sign in the pictures. *Initially, my bike was in gear and when I touched the ground end of the lead to the metal part labeled with the '-' in the pictures, the lead sparked, the bike edged forward and tried to turn over. *This was my first clue I was bipassing the entire ignition system (yea, i should have stopped at this point, but I didn't). *So I put the bike in neutral and tried to reconnect the ground lead to the metal part. *The bike didn't edge forward, and my clock came on. *I let it sit for a second, then turned the key (the bike turned on). *I have a CBR 4fi so I pushed in the FI switch to prime the pump, and then hit the ignition, everything started up fine. I waited a minute, removed the cables, and got ready to go. *As soon as I started riding the bike I noticed something wasn't right. *From 2-5k it wasn't pulling very well, and it seemed to almost be misfiring. *Then, when I was switching gears, the bike died altogether (I originally thought this was becasue the battery was completely dead but it has happened since, and I know my battery is fine now, I've tested it). *When I pulled over I noticed when the bike was idling it wasn't idling steadily, although the difference in revs was probably less than 100 revs/min so not that noticable. *However, the lights were flickering at the same time when the engine speed changed. *Then I thought it might just need to charge the battery, so I held the throttle (bike is stopped at this point) at around 5k revs. *Even though I held the throttle steady I noticed through the tach (barely) and by the engine noise, that the speed of the engine was shuttering a bit. *When I let go of the throttle to let it idle, the bike died altogether. *I left the bike there (random neighborhood) and headed to work with my friend who was nice enough to drop me off. *
I went out there that night and tried to jump it correctly - this time connecting the leads to the battery. *Nothing happened. *I decided to take the battery with me and charge it for a day. *That night it stormed pretty much all night. *I wasn't able to get back out there to put the battery back in for two days. *When I finally did, the bike seemed to run well again - started up without any issue. *It rode ok for a couple days after that, but since has started to buck again when the throttle is held steady. *The 'FI' light has come on once or twice when this gets pretty bad. *I think I may have either messed up the ECM by connecting the car battery incorrectly, or it is an issue with something else that's electronic. *My bike has a little over 4k miles on it and has never been down, so I don't see it being an engine issue. *All fluids were changed at 2500 miles. *Please let me know what you guys think and what I should check (if I can do it at home, I have some access to pretty good tools), and what issues might cause the symptoms I'm seeing. *The pictures are attached.
September 2, 2009, 11:51 PM
I will upload the photos tomorrow when i get a chance. I'm on my phone right now and for some reason can't upload them. Thanks in advance for any help.
red t3d r1's Avatar
September 3, 2009, 02:36 AM
get a new battery
September 3, 2009, 07:23 AM
A motorcycle battery does not survive a complete drain very well. My friend's 08 CBR600 would die without warning when his battery was shot. We put cables from a car on it, and it was fine. Took the cables off, it ran for a minute or two, then died.
BTW as a reminder to everyone, always jump a motorcycle from a car battery alone and not the car's electrical system. In otherwords, never start the car. Leave it turned off. Otherwise the current is too high coming into the bike.
September 3, 2009, 08:31 AM
here are the pics of where I connected the leads coming from the car battery. The positive lead is designated by the '+' and the ground is designated by '-'
September 3, 2009, 08:36 AM
Originally Posted by red t3d r1 View Post
get a new battery
I don't think it's the battery. The bike has never failed to start after recharging the battery, and I had the battery tested two nights ago - it was putting out 320 volt-amps which I think is more than enough for a motorcycle battery. I really think it's the ECM, but I have no way of testing it.
September 3, 2009, 08:37 AM
Begin with a new battery.
September 3, 2009, 08:42 AM
I vote for battery
old fat and slow
bambam's Avatar
September 3, 2009, 08:43 AM
check the fuses first
then have the battery load tested
MissS:no now!!!
MissS: I changed my mind
September 3, 2009, 08:44 AM
Read 2 posts above.
He had the batt load tested.
get a new battery
tru...anything you do before getting a new batter is pretty much pointless.
once a battery is drained, it's pretty much a rap. Plus it will cause other major components of ur charging system to work harder.
1. the plates on the inside can fuse together = battery death
2. the battery never really "fully" recharges, as it will only charge back up to the amount of power it can store (some shit like that how it was explained to me )
oh..and don't work on the bike when ur hammered
September 3, 2009, 08:46 AM
flash ur ECM.
1. disconnect your battery
2. disconnect your ECM
3. wait a few minutes
4. plug in your ECM
5. plug in your battery
Test ur stator too
or you could just drop the $120 for an electrical diagnosis at fairfax cycles...since ur already in fairfax.
SMB
sans motor bike
SMB's Avatar
September 3, 2009, 09:00 AM
+1
*wow you actually remembered*
flash ur ECM.
4. plug in your ECM
Test ur stator too
Thanks, I'll try that. How do I test the stator? If it's not the ECM then I really don't know what it could be - it has low mileage and was well taken care of so I can't see it being something mechanical. Plus it's run perfectly (no problems at all) up until the morning I jumped it incorrectly. The jump may have messed up the hardware on the ECM and flashing it may not work, but that's a good starting point.
SMB
sans motor bike
SMB's Avatar
September 3, 2009, 09:03 AM
you can do a simple load test if you have a multimeter....but +1 to buy a new battery,
FWIW those auto parts stores will do a FREE load test
