» Online Users: 544
1 members and 543 guests
rokshox's Avatar
July 7, 2004, 07:45 PM
suggestions on how to keep the bracket centered when you are torqueing the steering nut down? Thanks
Ummm...yeaaah
EL ZEE's Avatar
July 7, 2004, 08:19 PM
Insert small flat head screw driver between the triple and the bracket on the left hand side. Hold it vertical between the surfaces of both. Kinda like a door stop. Just wedge it in there. This will keep the bracket from turning.
Side Note:......."Damper"
El Zee
CCS MA EX#96
http://www.cornerspeed.net
  Send a message via AIM to Send a message via AIM to EL ZEE
Twiggy6's Avatar
July 7, 2004, 08:22 PM
say it with me.... Damper. Try holding it in place when you torque it. What's called for as the recommended torque? Can't be too much. 80lbs maybe?
Twiggy6's Avatar
damn you Dark I was looking up torque specs
rokshox's Avatar
July 7, 2004, 08:27 PM
82 lbs to be exact, thanks
Ummm...yeaaah
EL ZEE's Avatar
July 7, 2004, 08:28 PM
Damn me? Damn you... 80Lbs is a about right.
Let's all say it together.........DAAAMMMMPER
El Zee
CCS MA EX#96
Twiggy6's Avatar
July 7, 2004, 08:46 PM
My guess was off the cuff too.
try googling Torque specifications sportbike and see what you get.
God of the Gaps
Cripes's Avatar
July 8, 2004, 08:39 AM
I just put on my Ohlins dampeninger the other day. I'm assuming you've already broken off the little tab? Saw on the Fireblades site that this could be a problem so went with recommendations I found. Held the bracket in place while torqueing, also put some grease between the bracket and nut.
