» Online Users: 607
0 members and 607 guests
Problem with headlight on my ZX6
blueboxer's Avatar
Problem with headlight on my ZX6 - June 17, 2006, 10:00 PM
Here's the problem and I cant figure it out.
I have the dual lamps on my 02 ZX-6.
I noticed today that one of my head lights it out, when I have it on low beam.
But when I have it on high beam, both lamps come in.
Any help?
Cruisin the Autobahn
June 17, 2006, 10:08 PM
double check in the manual that that's not how it's supposed to be. i think that's how the Yamaha R6s work too...
'05 Ninja 500R - SOLD
June 17, 2006, 10:13 PM
here ya go
http://bcsportbikes.com/forum/showthread.php?p=567917
June 17, 2006, 10:25 PM
yeah, your highbeams are seperate filaments. Replace the headlight with the tanked low beam.
2016 Concours 1400
blueboxer's Avatar
June 18, 2006, 08:40 PM
I cant recall which bulb it is (riders left or right) that stays on while the high beam is on. And since it doesnt work, there is not way for me to check.
Anyone have a ZX6 to check for me?
June 18, 2006, 09:04 PM
Looks like the left.
Forklift+snowbank=stuck
billetbong's Avatar
June 18, 2006, 09:15 PM
ok, so bike has two bulbs, only one lights on the low beam circuit, can you just swap the bulb with the burnt filament into the side that only lights with the highbeam? or is it two different bulbs? I know my r1 uses two identical bulbs despite only one headlight being lit with the low beam, if your kawi is the same you could just pull a swap with the two bulbs and the problem is solved.
  Send a message via AIM to Send a message via AIM to billetbong
blueboxer's Avatar
June 19, 2006, 08:09 AM
I tried that and it didnt work. The bulbs appear to be the same based on the info printed on the bulb. I will go get a new left bulb and see if it works. Thanks the help
blueboxer's Avatar
June 21, 2006, 03:13 PM
I purchased a new bulb and it worked, so I assume that the left bulb and right are different.
well now that I have it fix, there is another problem. The light switch is backwards. Meaning, when I turn the switch to high beam the HB indicator light comes on and only one headlight is showing. When I turn it on LB both head lights are one with the indicator light off.
Oh well, I can live with it.
June 21, 2006, 03:25 PM
interesting...i would continue to tweak it in that case...it becomes a safety thing - when you want those high beams, you DEF are gonna want both. ridin around at night around Fredericksburg, my one (bigger than one of your lights) high beam doesn't even really cut it.
