» Online Users: 482
5 members and 477 guests
2blueyam, dubplaya, legendindisguise, Sal_the_man, tonetone
Fuzz Runna
ND4SPD's Avatar
August 4, 2003, 10:12 AM
Alright, need some help fast..no, not for my bike, for Wheel's SVS. The front right motor mount is stripped out, the one with the right side frame slider. :mad2: I need to know if anyone has the tools and/or experience in re-tapping motor mount threads.
PLEASE POST UP!! Thanks in advance!
drdoom's Avatar
August 4, 2003, 10:18 AM
i guess dropping your bike at a twt strips the thread
  Send a message via AIM to Send a message via Yahoo to drdoom Send a message via AIM to drdoom
Wheels's Avatar
August 4, 2003, 10:31 AM
Clearly it has nothing to do with that I'm definitely taking it to the shop
WHEELS
All life is an experiment
  Send a message via AIM to Send a message via AIM to Wheels Send a message via MSN to Wheels
God of the Gaps
Cripes's Avatar
August 4, 2003, 10:33 AM
You've got more than one engine mount. Just consider the broken one the "spare" and try not to break another one.
Fuzz Runna
ND4SPD's Avatar
August 4, 2003, 10:40 AM
well, it's not a huge deal, just need the tools to repair it..maybe 30-45 min fix....
girl, chill...we can fix it a lot quicker and cheaper than a shop
[Edited on 4/8/2003 by ND4SPD]
August 4, 2003, 10:47 AM
re-tapping aluminum is a bad idea, go with heli-coils, i had a problem with a frame slider that stripped the frame on my bike tried to re tap and aluminum just turned to butter, the coils will hold up much better and you can get em at any auto store/hardware store.
Fuzz Runna
ND4SPD's Avatar
August 4, 2003, 10:51 AM
are you familiar with how to do/complete this process?? If so, please let me know so we can maybe get it done this week some time. Oh, and it's the motor that is stripped, not the frame. Using heli-coils (no clue what the hell that is), will it allow you to use the same bolt? or will it need to be resized. Thanks for your help!
Tifosi's Avatar
August 4, 2003, 11:44 AM
I'd make the guy that mounted the sliders without the proper Torque Values(they are freaking motor mounts after all) and lube pay for half of the repair :mad2:
I agree with zx6rfool, the helecoils are a lot stronger than just re-tapping the hole with a larger diameter thread. The Helecoils come in kits and are pretty easy to install...
After all, the Military specifies using Helecoils in place of taping aluminum
Give CAD cycles a ring...
Tifosi
Fuzz Runna
ND4SPD's Avatar
August 4, 2003, 11:51 AM
Tifosi
I put the sliders on...and they weren't torqued that tight, even without a torque wrench...and lube for what? I did put lock-tight on......
125cc weedwacker
BBR6's Avatar
August 4, 2003, 11:52 AM
More than likely, they are going to have to drop the engine in order to helicoil it. When you helicoil something, you have to drill the hole a larger size, tap it, then install the helicoil. Usually helicoil kilts have all the pieces necessary to do the job. Take it to a shop.
1998 Honda RS125 -Living room show piece
Tifosi's Avatar
August 4, 2003, 12:14 PM
Bottom line is, her mounts are stripped due to your handiwork. Directions, Shop Manuals, and Torque wrenches are made for a reason
Also, loctite has many different applications (bonding, gasketing, thread locking, thread sealing, etc.), so picking any ol' package off of the shelf doesn't cut it...
Tifosi
Fuzz Runna
ND4SPD's Avatar
August 4, 2003, 12:24 PM
Tifosi
So, you're saying you use a shop manual to put on frame sliders?
And it was thread lock lock-tight....get all the facts before you talk out yo a$$
it was not over-tightened, I've put on/taken off plenty of aluminum treaded bolts/mounts, and know what would be too tight....
why don't you attempt to say something to assist in repairs as opposed to just talking $hit man...come on now, we all have a common end goal- to get her bike fixed, so that is what this thread is for... not flaming- thanks
Fuzz Runna
ND4SPD's Avatar
August 4, 2003, 12:33 PM
how's that Woody ?
August 4, 2003, 12:37 PM
Brandon, if it wasn't over-tightened, what happened? I have an SV and don't want to end up with the same problem. Is there something tricky about the way that the engine mount bolts are installed?
R1Myers's Avatar
August 4, 2003, 12:41 PM
I wouldn't use lock-tite with aluminum, only cast iron. That could be the reason the threads are gone.
Anyway, re-tap the stripped threads and use a helicoil and tighten the motor mount.
Tight is tight and too tight is broke. Make sure you use a helicoil though, otherwise it will just strip again. Hope that is some help
