» Online Users: 542
3 members and 539 guests
2blueyam, amit, CCS762ZX6
July 5, 2005, 10:34 AM
My tach is acting ridiculous. Here's what happens:
1. with bike started
- tach reads 0 rpms for 3 seconds, jumps to 3k rpms for 2.5 seconds, reads actual rpms (whatever you have the engine running at) for 3 seconds, repeat (back to 0 for 3 sec, 3 for 2.5 sec, actual for 3 sec)
2. Bike not started, key in on position
- tach reads 0 rpms for 3 seconds, jumps to 3k rpms for 2.5 seconds, reads 0 rpms for 6 seconds (3 seconds on 0 for actual rpms as the bike is not running, then 'normal' 0 for 3 sec).
So, I can look at the tach approximately every 6ish seconds for actual useful information actually starting to get used to it.
This was not a problem until I went through the carb cleaning/syncing process (which I will now be leaving to the professionals). Obviously I disconnected and reconnected stuff and something got upset in the process. I'm stumped, your expertise would be appreciated.
edit: this is a '99 R6
Retired to most ...
JohnnySpeed1KRR's Avatar
July 5, 2005, 10:43 AM
You accidently incerted hose A into slot C while crossing wires 1 and 4 within hose B. Simply remove wires 2 and 3 from hose C (located in slot B) and connect them with wires 1 and 4 from the before mentioned hose. Once this is completed remove hose a from slot C and incert into hose B. This insertion may require some pressure. Once this is completed cap off slot C and any visible wires.
PROBLEM SOLVED!!!
July 5, 2005, 10:45 AM
John lay off the crack.
Retired to most ...
July 5, 2005, 10:50 AM
Wouldnt it scare you though if you looked at his tach harness and I was right???
Yeah how ya like me now biotch!!!!
Nothing here
Madali's Avatar
July 5, 2005, 10:52 AM
These are simple trouble codes telling you what is wrong. Check your manual for the code or call a shop.
July 5, 2005, 11:10 AM
madali, thanks for the reminder. Actually I forgot to check for trouble codes.
john, go sell a car - post whore.
Retired to most ...
July 5, 2005, 11:11 AM
