» Online Users: 524
1 members and 523 guests
Nobrains
100% Kawasaki Biased
Thomas's Avatar
May 18, 2005, 10:32 AM
I put the stock muffler on my 99 Zx-6r the other day to get it inspected, shortly after doing so I noticed a ticking that I did not/ could not hear with the after-market pipe. It will tick at any rpm but you must be on the gas at least a little, It does not make any sounds when downshifting regardless of rpm(while slowing down).
I was told that it could be runing lean or need a carb sync, it could be a valve adjustment, or even detonation. Any ideas or advice??
Whatever it turns out to be I would like to do the job my self so if anyone has any experiance with this sort of thing let me know and I will make it worth your while if you want to guide me through it. Thanks for your help.
You can live in your car, but you can't race your house.
'07 ZX-10R - 156 RWHP/182 MPH
'09 KX450F - VCHSS 29F
'85 ZL-900 Eliminator
'01 Ninja 250 (Sold)
'06 636 (Sold)
'99 ZX-6R (Sold)
'94 Ninja 250 (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htmfeature=related
The difference between men and boys is that boys make excuses and men make changes.
May 18, 2005, 11:08 AM
I may make myself look dumb here, so someone please correct me if I'm wrong. But I believe anytime you switch your exhaust in a carbed engine, you should rejet. I think it makes less of an impact if it's just a slip on, but still might be worth doing. As for experience, can't help you at this point. I really don't know if this will help your problem, but I thought I'd toss it out there for you.
May 18, 2005, 03:25 PM
I don't know without hearing it myself.
Thomas's Avatar
May 19, 2005, 04:15 PM
Its just a slip on, but what is odd is that it makes the noise with the stock muffler....thanks for your help.
'06 636 (Sold)
'99 ZX-6R (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
boxing twins
hayabusafiend's Avatar
May 20, 2005, 12:04 AM
If the bike was jetted, it'll actually run richer when you mount the stock pipe.
Ticking noises are typically low oil level, old oil that's gotten very thin, low oil pressure due to low idle, or loose valve clearances (looser is better than tight).
That's your checklist.
Thomas's Avatar
May 22, 2005, 08:47 AM
the bike was not jetted, I use mobil 1 and change it every 3K, idle is within spec 1300+-50 I think its just a valve adj. does anyone know how to change the shims? do I have to remove the cams??
'06 636 (Sold)
'99 ZX-6R (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
Thomas's Avatar
June 1, 2005, 11:01 PM
OK so I syncd the carbs(barely off at all) adjusted the valves(needed none) and changed the plugs, still makes the noise, I think it must be an exhaust gasket around the headers or a cam chain tensioner.. I will let you guys know the parts should be on the way....
'06 636 (Sold)
'99 ZX-6R (Sold)
'99 YZ-250 (Sold)
'73 CL 450 (Sold)
June 2, 2005, 10:13 PM
I would guess exhaust leak seeing as that is the last system you were messing with.
R1Myers's Avatar
June 4, 2005, 11:40 AM
ZX6 and ZX9's are noisy bikes by nature. I believe they have looser clearances than most bikes.
June 5, 2005, 03:50 PM
Put your louder pipe back on and then get at the engine with a good ear. You'll be able to rule out, at that point, whether or not the noise is exhaust related. If it is, no worries. Othewise your tolerances may be loose... if you want to crack the case open you could go at it with a feeler gauge - if you want.
  Send a message via AIM to Send a message via AIM to asteele2
June 5, 2005, 04:57 PM
The tick would be at the head. The slip on would only mask the noise.
2018 XSR700
June 5, 2005, 08:04 PM
I dont think the pipe was the cause of the noise. When you put the quieter pipe on you could actually hear the noise. If it is the valves, you got alot of work ahead of you. It may be a normal noise. My 636 has ticked since like day one. .
On a side note, I dont think the bike running rich or lean would cause any ticking, just sputtering and backfiring.
June 5, 2005, 08:53 PM
Sometimes injectors on EFI bikes tick. Obviously the 99 is not EFI..but your 03 is.
2018 XSR700
FZRCris's Avatar
June 5, 2005, 10:12 PM
Ninjas are noisy bikes anyways, you probably didn't notice it with the slip on on the bike. My 250 was a noisy sumabitch, and even my fzr makes alotta noise when I have my quiet exhaust on it.
To check for detonation, get on a hill at a (relativly) low RPM and give it some gas. It should be noticable sound like BB's bouncing around. Somehow I doubt that would be it though.
All else fails, screw driver to the ear and try to hear where it is coming from while it is sitting still (Unless you can put your ear to it while riding )
'95 FZR600 with R1 tail "Machina"
I'll fix my seat at some point.
Boomie's Avatar
August 30, 2005, 02:56 PM
Does your bike have hydraulic lash dampners on the valves? If not, the valves will tick and can get louder when hot. Swtiching from loud to quiet pipes can make that particular noise stand out dramatically. Also (if it applies) changing helmets can make it stand out more.
Also note that valves tend to tighten, not get loose so they will get quieter when out of spec.
  Send a message via AIM to Send a message via AIM to Boomie
