» Online Users: 546
1 members and 545 guests
Tifosi's Avatar
August 27, 2004, 08:26 AM
I understand that by using tire warmers I will basically be putting my tires through one heat cycle versus several heat cycles by not using tire warmers during a typical track day.
I'm not worried about tread life/depth because my bike manages tires pretty well, but I'm starting to worry about the tires suddenly going off because of too many heat cycles ...I'm using the Diablo Corsas.
How much more tire life can I typically expect by using tire warmers vs. not using tire warmers?
Thanks in advance,
Tifosi
old fat and slow
bambam's Avatar
August 27, 2004, 09:54 AM
jason.. for a trackday i really think that tire warmers would be a waste. i mean you take it easy for the first lap and then you're good to go. tire warmers only real benifit would be to allow you to go at it harder right off the line... ie. racing for turn 1. there was a big write up about this on the nesba board not to long ago. not to mention that the diablo corsa's are a "trackday" tire designed to handle those heat cycles. imho you could also over cook your tires causing even less wear and more problems.
MissS:no now!!!
MissS: I changed my mind
