» Online Users: 534
2 members and 532 guests
Heist, tonetone
Go Back   DCSportbikes.net > Brand Specific > Aprilia
RSV4-R - Factory on a budget
RSV4-R - Factory on a budget - September 29, 2009, 02:53 PM
Have a launch video:
http://www.youtube.com/watch?v=6AsBV...layer_embedded
This bike looks like the smart buy, close but not quite the Factory - but for lot less $$$.
US price is yet to be released (UK is selling for around 20K, expect something closer to 15K here)
Where does the R differ versus the Factory?
here are the changes:
UK spec sheet:
which says:
APRILIA RSV4 R: Technical specifications
Engine type Aprilia longitudinal 65° V-4 cylinder, 4-stroke, liquid cooling system, double overhead camshafts (DOHC), four valves per cylinder
Bore x stroke 78 x 52.3mm
Total engine capacity 999.6 cc
Compression ratio 13:1
Maximum power at crankshaft 180 CV (132.4 kW) at 12,500 rpm
Maximum torque at crankshaft 115 Nm at 10,000 rpm
Fuel system Airbox with front dynamic air intakes.
4 Weber-Marelli 48-mm throttle bodies with 8 injectors and latest generation Ride-by-Wire engine management. Choice of three different engine maps selectable by the rider with bike in motion: T (Track), S (Sport), R (Road)
Ignition Magneti Marelli digital electronic ignition system integrated in engine control system, with one spark plug per cylinder and “stick-coil”-type coils
Exhaust system 4 into 2 into 1 layout, single lambda probe, lateral single silencer with engine control unit-controlled butterfly valve and integrated trivalent catalytic converter (Euro 3)
Lubrication Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling)
Clutch Multi-disc oil-bath, with mechanical slipper system
Frame Aluminium dual spar frame with cast and pressed elements
Sachs steering damper
Front suspension Upside-down Showa fork with 43mm stanchions. Aluminium radial caliper mounts. Completely adjustable spring preload, hydraulic compression and rebound damping. Wheel travel 120mm
Rear suspension Double braced aluminium swingarm; mixed low thickness and sheet casting technology.
Sachs monoshock fully adjustable for spring preload, ride height, hydraulic compression and rebound damping. APS progressive linkage. Wheel travel 130mm
Brakes Front: Dual 320mm diameter floating stainless steel disc with lightweight stainless steel rotor and aluminium flange with 6 pins. Brembo monobloc radial calipers with 4 x 340mm opposed pistons. Sintered pads. Radial master cylinder and metal braided brake hose
Rear: 220mm diameter disc; Brembo caliper with two 32mm isolated pistons. Sintered pads. Master cylinder with integrated reservoir and metal braided hose
Rims Front: aluminium alloy with 6 split spokes - 3.5”X17”
Rear: aluminium alloy with 5 split spokes - 6”X17”
Tyres Radial tubeless.
Front: 120/70 ZR 17
Rear: 190/55 ZR 17
Dimensions Max. length: 2040mm
Max. width: 735mm (at the handlebar)
Max. height: 1120mm
Min. height from the ground: 130mm
Saddle height: 845mm
Centre to centre distance: 1420mm
Trail: 105mm
Steering angle: 24.5°
Kerb weight 184kg *
Tank 17 litres (4-litre reserve included)
cheers hfl and SuperBike
Masarap's Avatar
September 29, 2009, 03:00 PM
Verry Niice!
What failure looks like
nrcooled's Avatar
I would love to have one but it just seems like "so much bike" to me. I feel like one would be completely wasted under my ass. For 15k though it's damn tempting.
BTW - when are these coming to the states?
'04 600RR - Street
TPM #101 - Blue
NESBA #101 - Advanced
MatDady1's Avatar
September 29, 2009, 03:07 PM
Not in love with the stock exhaust, but that's one sexy tail
'08 CBR 600RR
'04 CBR 600RR track
www.MohawkRyderz.com
  Send a message via AIM to Send a message via AIM to MatDady1
Asstastic
#452-LE's Avatar
September 29, 2009, 05:07 PM
The white one is dead sexy.
http://www.youtube.com/view_play_lis...844F779ADF89CA
http://www.youtube.com/watch?v=WNDlf6hA6TY
Michael Collins: You are the baddest mo-fo low down around this side of town!!
Whip some ass!!
B.J. Penn: Sho-nuff!
2 wheels for life
Deep's Avatar
September 29, 2009, 09:57 PM
Like the ergos
Adrenaline Addict
September 30, 2009, 11:01 AM
Aside from looks, what exactly makes it similar to factory R? It doesn't even have Ohlins suspension, or case covers, or rearsets, or better brakes, which I presume factory does.
I dig the looks...
September 30, 2009, 11:06 AM
which is interesting, I believe the previous R did... ?
Yes, I believe so, but my memory could be failing me here...
September 30, 2009, 11:09 AM
i want one i have no monies...
CCS AM # 204
Crackdays for everyone!
ZX-Matt's Avatar
September 30, 2009, 12:38 PM
Pretty sure rv1000r had ohlins front and sachs in the rear. factory r gave you ohlins rear and some other goods.
Matt K.
09 R6
  Send a message via AIM to Send a message via AIM to ZX-Matt
Toe Dragger
DucDucGoose's Avatar
September 30, 2009, 01:24 PM
I spoke to the North America Technical rep about the bike at ViR and sat on the one he had.. TINY TINY TINY feeling motorcycle with very comfortable ergos, at least for a 6'2" person.. Might be cramped in a full tuck though.. Sounds absolutely wicked to boot.. He said it should be priced around the 1198 or just a bit below which makes sense.
Chad
Sales Manager Duc Pond Motosports
I Make you Ducati Dreams Come True... LOL! Seriously! I do!
1999 Ducati 996 (sold)
1998 GSXR600 track bike (shamu) sold..
2008 Kwaki Versys sold...
2006 VFR800 Sold..
2001 Road King? Yep....
Owner of the Site Owner
September 30, 2009, 02:55 PM
biaggi makes the bike look small.
i feel like you have to be sub 5'10" for this bike
I tow 747s
"gixrB: I like it hard, with a lot of feel"
Tough guy
CamDLux's Avatar
September 30, 2009, 08:07 PM
I'll wait for the Tuono ergo version!
  Facebook Page Send a message via AIM to Send a message via AIM to CamDLux Send a message via MSN to CamDLux Send a message via Skype™ to CamDLux
October 1, 2009, 05:51 AM
