» Online Users: 540
2 members and 538 guests
2blueyam, nootherids
A bit of work on the Monster
got barrier?
dubplaya's Avatar
A bit of work on the Monster - July 21, 2013, 06:33 PM
So I've had this monster for maybe 3 years now....erbody and their mom has ridden it but its still fun. Either way I got home one day and found my rear wheel adjustment screw had backed off and somehow bent.....so like anyone logical i ripped it apart and we're starting fresh.....
04' monster 620ie
tear down
Cleaned and sanded (tail has been chopped as well but that was about 2 years ago)
New Paint
Tank was dented by my friend's fiance dropping it so i stripped the tank down repaired the dent and respray (the paint was in bad shape so it needed it anyways)
(second layer)
(base coat complete)
need to clear coat it and then do the fender and then on to motor work..
/justthoughti'daddbikecontentto.NET
DUCATI MONSTER
rubber ducky?!
Ni Hao Ma, Bitches!
lemond's Avatar
July 21, 2013, 08:18 PM
dig the new frame color, what is it?
2006 Husqvarna 510sm
2006 Honda 919
1995 Ducati MOnster 900 - sold
2000 Suzuki GSXR 600 Track Bike - sold
  Send a message via AIM to Send a message via Yahoo to lemond Send a message via AIM to lemond Send a message via MSN to lemond
No more 1050 :(
drz1050's Avatar
July 21, 2013, 08:53 PM
How did you repair the dent? Were you able to pull it out?
July 21, 2013, 09:01 PM
Great color choices. Curious to see the final product
Cager
JarvisB's Avatar
July 21, 2013, 09:14 PM
Looking good sofa!
Would love to know how did you repair the dent too, if you dont mind sharing. I have a dent on my tank that I am looking to fix.
Also, I am wondering if you used rattle can spray paint? Which one did you use? Tank looks good at least in the pics Thanks in advance!
-J. Beaver
--bike-less for now
July 21, 2013, 09:16 PM
Noice! What kind of product are you using?
July 21, 2013, 09:30 PM
Noice!
yuu
Whitty comment
yuu's Avatar
July 22, 2013, 07:56 AM
Depending on the dent - either just fill and shape - sucking up the fact you're losing some volume. This is pretty common for the Monsters Ducati Ding as it's high up on the tank and really doesn't effect the volume. That common ding comes from the switch gear hitting the tank if the bike is dropped or lowsided. It'll be right by the D of Ducati on the left side and the I on the right
If it's in a different spot from some "miss handling" - probably starting with a weld on stud dent puller then reshaping. Or just some fill if it's shallow, or one that won't pull out
- Throttle's on the right. So are the brakes. Good luck.
got barrier?
dubplaya's Avatar
July 22, 2013, 09:58 AM
The dent was from someone dropping the bike on its side from a practical stand still. The bar bent back and hit the tank, right by the D as mentioned.
I used the heat and cool method to "pull" the dent as much as possible. Once that was done I used lightweight filler to shape.
Frame color is Duplicolor Charcoal metallic I believe, I'd have to go look at the can. Its darker than the OEM ducati color. (Advanced Auto Parts) and then three or so layers of clear and then baked.
Tank is VALSPAR Yellow (Lowes)
and then VALSPAR Clear will be used
I used VALSPAR clear on my Audi wheels and it holds up very well. Although it doesn't have that OEM automotive hardness to it. I'm waiting about 2 weeks before I wax everything.
DUCATI MONSTER
rubber ducky?!
Stop light racer...
pnbell's Avatar
July 22, 2013, 10:31 AM
Excellent project!
I'm curious; do you know if the Paint/Clear coat you're using are Gasoline resistant? I've painted a few motorcycle tanks and usually use Rust-o-leum 'Stops Rust' Enamel because it is Gas resistant; However their clear coats are not Gas resistant.
If unsure, you might consider painting a test piece and then pouring some Gas on it to see what happens. **Instead of testing this on your bike the first time you get gas!
I'm just curious. Bad Experience: I painted a tank Silver once; it looked great until i wiped a drop of gas off it and took a layer of paint off with it!
- Sold, Red 81' GS650
- Sold, Black 81' CM400T
got barrier?
dubplaya's Avatar
July 22, 2013, 02:11 PM
I'm more than sure that it is not gas resistant. However i have a clear bra for the tank.
DUCATI MONSTER
rubber ducky?!
Stop light racer...
pnbell's Avatar
July 23, 2013, 09:27 AM
Ok, yea. Take some sort of precaution for sure. It would suck to have your awesome new paint job get melted by a accidental drop of gasoline.
Keep up the good work though!
2A all the way
mdracer76's Avatar
October 18, 2013, 12:48 PM
Any updates?
2013 Panigale S
  Send a message via AIM to Send a message via AIM to mdracer76
