» Online Users: 575
4 members and 571 guests
2blueyam, GsxrBulldog, nootherids, Slider
Kawasaki 2012 Products: KX 250/450
Я - Ребенок Люциферов
vonstallin's Avatar
Kawasaki 2012 Products: KX 250/450 - May 17, 2011, 07:17 PM
2012 Kawasaki New Product Launch
Unlocking the secret recipe for a holeshot has traditionally been up to the rider. Now, Kawasaki steps in with a helping hand, thanks to a brand-new launch control feature on the 2012 KX450F.
Refined into a more powerful, more versatile and all-around more effective motocross . . . more
A total width reduction of 4mm across the main spars gives the 2012 KX450F the most . . . more
Unlocking the secret recipe for a holeshot has traditionally been up to the rider. Now, . . . more
No other production motocrosser offers a higher degree of adjustability to the rider . . . more
The new 2012 KX450F offers a choice of four different handlebar positions, more than any . . . more
A new embossed logo on the clutch cover features a trick design that reveals a raised . . . more
The new wave-type front brake rotor is solidly mounted to reduce complexity and unsprung . . . more
Minimal body work, revised shrouds and smaller number plates contribute to the slender . . . more
Maps can quickly and easily be changed between three settings – standard, hard . . . more
The DFI's ignition map coupler is mounted to the right side of the steering head, . . . more
The KX450F delivers improved mid-to high-end power delivery with a wider powerband, . . . more
The new fuel tank has a shorter overall height and a narrower top section, which forms a . . . more
A new fuel tank, upgraded bodywork and a shorter muffler help relocate weight toward the . . . more
The silencer is a full 60mm shorter than its predecessor to help improve mass . . . more
The Kayaba Air-Oil-Separate (AOS) fork keeps oil and air in separate chambers for . . . more
The tie rod arms of the Uni-Trak® rear suspension linkage are now slimmer, offering . . . more
The DFI's coupler plug is mounted to the right side of the steering head, simplifying . . . more
Overview
No other bike in its class has spent more time on the AMA Supercross podium than the Kawasaki KX™250F. The race-proven technology of the quarter-liter motocross leader returns for 2012, but with added enhancements that give the KX250F even more usable power, increased durability, and the best-handling chassis yet.
As the KX250F continues to lead the way in stadiums, it also continues to win the favor of enthusiast publications, who repeatedly name it a gold standard in motocross machinery. The KX250F offers cutting-edge technology right off the showroom floor, to give riders the winning edge on the track. Along with the KX250F’s race-proven performance, no other production motocrosser offers as much adjustability, fine-tuning capabilities and rider customization when it comes to motor and suspension. Right off the production line, the KX250F gives a factory advantage to the privateer racer – the difference between scratching for a podium and dominating a championship.
For 2012, Kawasaki engineers sought to create a KX250F with even more impressive top-end performance, which they accomplished by equipping its Digital Fuel Injection (DFI®) system with a second fuel injector –a first for use on production motocross bikes– located near the airbox intake. The all-new “upstream” injector helps build a wider and more potent spread of power as rpm climbs. The two fine-mist atomizing injectors that feed the 250cc four-stroke powerplant are distinct in appearance with different body sizes, but deliver the same per-cycle capacity. Together, Kawasaki’s dual injectors pack a one-two punch, delivering a second dose of fuel on acceleration to increase the high-rpm power and overrev capabilities of the KX250F.
The KX250F is finished with quality race-proven components such as a Renthal aluminum . . . more
The all-new “upstream” injector helps build a wider and more potent spread of power as . . . more
The 2012 KX250F motocrosser features even more impressive top-end performance, which was . . . more
The already innovative Separate Function Fork (SFF) was improved for 2012. The fork . . . more
A slightly shorter stroke of the shift fork and a solid (rather than hollow) shift rod . . . more
The optional DFI® calibration kit allows for custom tuning. It uses the same connector . . . more
The KX250F is frequently praised for its rider interface and natural layout that fits a . . . more
The Nightmare of Summit Point
WERA Nov# 325 / CCS # 326
