» Online Users: 637
4 members and 633 guests
beatle, dubplaya, GRN96WS6, HotRod1200
1k swap into K8 600 ?'s
1k swap into K8 600 ?'s - February 10, 2009, 09:36 AM
Will either the 05-06 or the 07-08 1k motor bolt right in or will I have to make mounts for either one of them?
Other than that say I went with an 05-06. I would need the wiring harness, ecu, speedo and controls correct?
And if i went with an 07-08 could I use my existing harness?
February 10, 2009, 09:42 AM
will not bolt in, a 750 will fit perfect just do that
CCS AM # 204
February 10, 2009, 09:47 AM
Neither.... hmmm
I want a 1k motor. Right now I have a turbo 600 but the head lifted on me so I yanked the motor out and was going to say screw it and swap a 1k motor in.
February 10, 2009, 09:50 AM
its not worth what it cost to modify....just buy a 1000
CCS AM # 204
February 10, 2009, 09:57 AM
Cost to modify isnt really the problem as me and my friend built my whole turbo kit so some mounts shouldnt be a problem. The swap is around 1500. And then I have to either fab some mounts or buy them. I heard somebody makes mounts but I cant find them. I just wasnt sure if they made mounts for the 05 and up 1k motors or if the newer motors even needed mounts to fit in a 600 frame.
Do you know if the 06 and 07 750 motors drop right into a 08 frame? If that works then I know alot of people have been dropping 1k motors into the 06-07 600 frames atleast in this area.
February 10, 2009, 10:07 AM
i dont think its a matter of the mounts i think its a matter of the 1000 engine is wider than a 600 frame, but i may be wrong....
CCS AM # 204
February 10, 2009, 10:09 AM
Im almost positive that isnt the problem. But then again i could be wrong because I have never swapped it either. Do you know about the 06-07 750 motors fitting in the 08 frame and mounting up?
February 10, 2009, 10:12 AM
you may need to fab some mounting brackets for that....i am not sure if they have the same mounting points, they are different generation bikes so the frame is different....
CCS AM # 204
February 10, 2009, 10:13 AM
call up fairfax cycles 703-591-8556 and talk to Kevin he knows alot about gixxers.
CCS AM # 204
February 10, 2009, 10:44 AM
Ok, thanks for all your input. It atleast got my mind rolling on some thing.
February 10, 2009, 12:35 PM
Check the gsxr forums, I know on the kawi forums people discussed swaps and interchangeable parts.
No matter what you would def need ECU, Harness, spedo, controls, radiator.
Your best bet is to find some one with a 1000 and take measurements, more than likely you will need to make brackets, however Im willing to bet this would require massive amounts of fabbing and frame cutting.
TEAM.SUKUZI
iceblizzxdc's Avatar
February 10, 2009, 12:41 PM
get a 1000. less work, more time for fun.
sex addict
POWERED BY SUZUKI GSXR1000
February 10, 2009, 12:45 PM
^ +1
CCS AM # 204
GiixerFiend7's Avatar
February 10, 2009, 01:52 PM
This dude is off gixxer.com he built a pretty sick turbo kit for his 600....
http://vids.myspace.com/index.cfm?fu...deoid=50200464
http://www.youtube.com/watch?v=CpldRhFAj8k
change.
This Ain't My First Time!
cf3232's Avatar
February 10, 2009, 02:33 PM
It has been done. Do some internet searches.
~Blutarski~
Dodge131:
