» Online Users: 609
2 members and 607 guests
gixxer123, GRN96WS6
Help...Gsxr cockpit no lights work
SRWJTS P.R.O.
Stylezx's Avatar
Unhappy Help...Gsxr cockpit no lights work - May 28, 2012, 01:27 PM
Okay so i recently bought handle bar mirrors and i finally got them in the mail...durning the install to get my stock mirrors off i cutt the wire that went to the turn singles.
Well when i got everything put back in place windsheild and mounted my new ones (looks good too lol) but i turned on my gsxr without looking at the dashboard or (cockpit) and drove the bike...when i finally looked down nothing is working on it..no lights speedometer , nothing at all..i tried rewiring everything the same way and still it wont work so i dont know..can anyone help me.
Originally Posted by RileysDad View Post
I'm happy to share some tips too....as long as you stop saying "yo" as the end of every sentence.
Xbox- xK1NG GwuaLLax ...see me on GoW3
K6 GSXR 600 - Sold
K7 - R6s ...sold thank god
K6 GSXR - never leaving you
PITTSBURGH BOY
R.I.P Dad 8-10-2012
hfam95's Avatar
May 28, 2012, 01:37 PM
I can't answer your question other than saying you forgot something, but why did you cut the wire if youre using bar end mirrors? I would have just used a wire nut or something. GL
Originally Posted by vonstallin View Post
Stinky:
Im so excited im about to pre-blast in my pants.....then....it hits me...
I smell her arm pits and i damn near threw up!!!!
  MySpace.com Page Send a message via AIM to Send a message via Yahoo to hfam95 Send a message via AIM to hfam95
SRWJTS P.R.O.
Stylezx's Avatar
May 28, 2012, 01:38 PM
i cut the wire to take the stock mirrors off..i dont know what i could of done different
K6 GSXR 600 - Sold
PITTSBURGH BOY
R.I.P Dad 8-10-2012
On vacation
RileysDad's Avatar
May 28, 2012, 01:42 PM
Sounds like a blown fuse. On the Gixxers, I believe one fuse controls the headlight and cluster gauge. Try that first and see what you find.
She asked my opinion
SRWJTS P.R.O.
Stylezx's Avatar
May 28, 2012, 01:48 PM
Okay cool, let me go try that one.
K6 GSXR 600 - Sold
PITTSBURGH BOY
R.I.P Dad 8-10-2012
Don't believe the hype...
w0bbles's Avatar
May 28, 2012, 02:43 PM
Simply unplug it from the harness?
Did you have the battery disconnected? If not, you probably contacted both positive and negative with the cutter when you cut the wire, causing a fuse to blow.
'11 Speedy
'72 CB450
On vacation
RileysDad's Avatar
May 28, 2012, 02:55 PM
Yeah but that should only happen if the key was in the ON position or the bike was running. Crossing the two shouldn't be a problem if the bike is off.
SRWJTS P.R.O.
Stylezx's Avatar
May 28, 2012, 02:58 PM
i checked the fuses and i blew one ...im pretty sure its for the cluster,but if i replace the fuse what should i do about the wires that just sitting around? i know i can tie them up in all but do i need to do anything with grounding them or nothing? I went out and bought fuses just incase i mess something up i have others to replace.
K6 GSXR 600 - Sold
PITTSBURGH BOY
R.I.P Dad 8-10-2012
On vacation
RileysDad's Avatar
May 28, 2012, 03:14 PM
You should already have spares in the fuse box. Usually one 10A and one 15A but it never hurts to have more on hand. There's a quick-connect plug for the mirrors so just trace the line you cut and find it. Unplug it, toss it, and you're done.
Taladis's Avatar
May 28, 2012, 03:15 PM
Just use electrical tape and tape them off.
Don't need to ground out or anything.
Just make sure they dont touch.
Knarly Adventurer
wildjester's Avatar
May 28, 2012, 03:33 PM
Sounds like you found your answers.
Totally unrelated, but somewhat relevant... you should check your cockpit before heading out. Just a quick scan for the basics; fuel, battery, oil, temp, etc.
2013 Triumph Tiger 800XC
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
On vacation
RileysDad's Avatar
May 28, 2012, 03:40 PM
Do NOT do this. This is fine for a temporary repair or to get you home but this is not a permanent repair cuz the tape WILL fall off, especially when capping off a set of wires since there's much less surface area to stick to and it doesn't stick well to itself. Plus, in the time it would take you to fumble around in there and wrap the wires, you could have unplugged the damn thing and be inside drinking a brew.
Sorry, but I did LMAO when he called it a "cockpit."
w0bbles's Avatar
May 28, 2012, 03:47 PM
Good point. I bet it happened when the wires were just dangling and he turned the key.
'11 Speedy
'72 CB450
SRWJTS P.R.O.
Stylezx's Avatar
May 28, 2012, 04:38 PM
okay so should i trace it alll the way back and remove all of it ?
K6 GSXR 600 - Sold
PITTSBURGH BOY
R.I.P Dad 8-10-2012
On vacation
RileysDad's Avatar
May 28, 2012, 04:42 PM
You will probably only have to trace it a few inches. Look for a gray or black square plug, you can't miss it.
