» Online Users: 628
2 members and 626 guests
CCS762ZX6, MPSniper
I wrecked...So Doth I rebuild
got barrier?
dubplaya's Avatar
I wrecked...So Doth I rebuild - July 25, 2007, 11:10 AM
Just making a bit of an online journal and build thread for my bike,
nothing too special going on. I'm upgrading a few things, redoing a few things at the same level, and in some peoples opinions probably down grading things.
But none the less here it is
I believe July 14th I wrecked my bike into a guard rail on a group ride and this is how she came out
Mechanical damages: Gearshift Shaft cracked @ the motor
phyiscal damages: both fairings were cracked, front hugger was shattered, nose cone was shattered, and right ram air tube was shattered.
so work begins
taking the body off the bike
stripped nasty paint off fairings, possibly fixable but probably need to order new ones
Brought the bike inside to my shed and with Audi's (john) help drained the fluids and removed the motor
I took off the right side to see parts that i had to work on in order to replace the gear shift shaft
yay for my clutch...looks clean in there
so since the motor is out to fix the shaft I decided to clean up the frame and replace some parts that are starting to wear
Using ENGINE BRITE gel to degrease the 7 years of junk
this is the result
(the bike stays on bike stands, but we had to carry them back to the shed first before we could bring the frame back)
the wheels were removed to be cleaned, painted and sprocket upgraded.
plans are to get SS brake lines, RK quick accel chain kit which is 16/42 setup with vortex sprockets, new brake pads f/r because mine are looking a little thin and old (7years) replace the brake fluid with better stuff, make the frame black, fairings will be white, and wheels a bronze (subi STi type)
probably cote the calipers in color as well.
If anyone has tips on removing a chain that would be great
also have to check my valve clearances
DUCATI MONSTER
rubber ducky?!
July 25, 2007, 11:15 AM
to remove a chain you use a cutting wheel or dremel by cutting the pins out of one of the links then you use a chain breaker tool to push the two nubs you ground down on the link out the back.
If the chain is a 530 you wont be able to use it with a sprocket setup (520) so you need to get another chain anyway.
What's today? aah fuck it
---> Venom <---'s Avatar
July 25, 2007, 11:17 AM
you're doin all this yourself??
coooooookie
Audicoupej's Avatar
July 25, 2007, 11:21 AM
I have an angle grinder Dan. We will get that chain off there!
John
'07 ZX-6R
NESBA #10
Sportbiketracktime #10
JEMM Auto detailing
Cars, Bikes, RV's, Trailers, bathtubs. If you pay me I will buff it.
got barrier?
dubplaya's Avatar
July 25, 2007, 11:32 AM
Ben I'm going to be ordering an RK KIT...which comes with 520 RK chain and VORTEX sprockets
RK 520 Conversion (steel) Quick Accel Kit for GSX-R750 00-03
? Feature lightweight wave design, 520 pitch steel sprockets
? Made from S45C induction hardened high-carbon steel, shot peened and zinc plated
? Slightly heavier than aluminum, these rear wave sprockets last 3 times longer than aluminum
? Kit specs:
Chain: 520XSO-110
Oem Gearing: 17-42
Kit Gearing: 16-42
RK Chain with Vortex Sprockets
I think this should work rather well for me
And yup I'm doing things with the help of John
DUCATI MONSTER
rubber ducky?!
Largely Unsupervised....
Corbett's Avatar
Removing chain...
I have a chain breaker tool, it is a handy item to own if you are keeping the chain.
Bolt cutters work better. Handy to own, if you are not keeping the chain.
This has been another fine contribution from Captain Craptastic.
2014 Harley Street Glide
'08 Brass Balls Bobber
'04 KTM 625 SMC
'78 Honda CB750K (soon to be mated to sidecar)
'07 SSR 125
'99 BMW K1200RS (SOLD)
'95 Honda Z50R (donated to a buddy)
'89 CR500R (SOLD)
'83 Honda CB1100F (SOLD)
'82 Honda CB750F (SOLD)
July 25, 2007, 11:42 AM
Time to streetfighter it.... I believe you could install an SV subframe and race tail without too much hassle.... give your baby an update...
got barrier?
dubplaya's Avatar
July 25, 2007, 12:03 PM
I'm not a street fighter nor naked bike fan, but she will look that way for a few while the fairings are being fixed/painted.
oh yea i forgot to mention i have to by a new rear subframe because the previous owner had bent/hack jobbed it
DUCATI MONSTER
rubber ducky?!
Chupathingy?
Sith4Brains's Avatar
July 25, 2007, 01:13 PM
Awesome work, even if it is a Zuki
Keep us updated Dan
PM me if your in H'Town, MD.
"Can't we go faster?.... Even if we rub cheetah blood on the engines?" -Phillip J. Fry
  Facebook Page Send a message via AIM to Send a message via ICQ to Sith4Brains Send a message via Yahoo to Sith4Brains Send a message via AIM to Sith4Brains Send a message via Skype™ to Sith4Brains
got barrier?
dubplaya's Avatar
July 25, 2007, 10:06 PM
Today's update:
We'll John and I were able to get a nice amount done
I dremel cut the chain off and removed the swing arm
Step one:
scuff/sand the frame
Step two:
degrease and clean the frame
Step three:
tape
Step four:
suspend/dry/make sure its clean and ready
Step five:
first coat of truck bed liner down (use Q tips in threaded holes, John's idea)
Step Six and Seven:
more layers and let dry
DUCATI MONSTER
rubber ducky?!
July 26, 2007, 05:42 AM
nice danny
  MySpace.com Page Send a message via AIM to Send a message via AIM to Kevmo
coooooookie
Audicoupej's Avatar
July 26, 2007, 06:45 AM
Step 8: cut a hole in a box
John
'07 ZX-6R
NESBA #10
JEMM Auto detailing
Spike
jtatooz's Avatar
July 26, 2007, 07:59 AM
wOw, great progress!!
SVJunkie's Avatar
July 26, 2007, 08:10 AM
Lookin Good! Are you using the textured bed liner?
Chupathingy?
July 26, 2007, 08:12 AM
truck bed liner? Why not a high heat color?
