» Online Users: 526
4 members and 522 guests
Nobrains, nootherids, Sal_the_man, Slider
Too Fat To Be Fast
BurnCycle's Avatar
February 25, 2005, 10:44 AM
Yoshimura Advanced Fuel Management System
This is the same box the dealer uses to remap your ECM on late model FI Suzuki’s. I picked up one a couple of years back to tweak my TLS when I made changes to it. If you want to tweak your Suzuki but don’t want to shell out the cash for the dealer prices or a Power Commander shoot me an email to burncycle@mariposaderojo.com and we’ll see if we can work an arrangement out.
This box will work on the following models…
01-03 GSXR600
98-03 GSXR750
01-02 GSXR1000
99-03 GSX1300R (maybe 04+)
97-01 TL1000S
98-03 TL1000R
The adjuster box allows for fuel map adjustments at four points:
1. Slow speed – Idle/cruising
2. Low throttle position acceleration
3. Medium throttle position acceleration
4. High throttle position acceleration
Fuel metering ranges from -10% injector duration to +10% injector duration, in increments of 5%. The YAFMS Adjuster Box does not alter the sensor input to "trick" the ECM into thinking that the air density or temperature requires a richer mixture. The box adjusts the map to increase injector duration. Sensor input will still function properly at all elevations and in different weather conditions.
  Send a message via AIM to Send a message via AIM to BurnCycle
