» Online Users: 527
0 members and 527 guests
4runner help
Noob-alishish
Derby's Avatar
4runner help - January 6, 2010, 10:54 AM
So guys my cuz and his gf come in to VA so Im showing them around....
I get pulled over for expired tags, got a warning yay.
So going home to get stuff to go get tags renewed.
On way home it starts to sputter from 0-25mph like it wants to die.
At idle its .5k rpms
So I finally make it home and as I pull in I glance down and my thermostat is almost in the red!!!!
I just put more coolant in it this morning because its leaking a little.
DANGIT ideas?
Cant afford to pay someone to fix it right now
Remember to Breathe.
Give me the Ban Button!
Nubbs's Avatar
January 6, 2010, 10:56 AM
Where is the coolant leaking from.
Sounds like it was over heating to me.
noise
static's Avatar
January 6, 2010, 10:59 AM
What year 4Runner? The early models were known to blow headgaskets on a regular basis. I think even Toyota came out with a "campaign" to fix vehicles.
Nubbs's Avatar
January 6, 2010, 11:01 AM
There is no need to scare the guy yet. Lets approach this with Tact and look at all the symptoms before jumping right into you have a major problem.
BE ENCOURAGED!
GUZZ's Avatar
January 6, 2010, 11:15 AM
Well I am no mechanic and think the guys at Jiffy Lube are, but doesn't this sound like a thermostat stuck wide open?
Playing in the dirt
jar944's Avatar
January 6, 2010, 11:20 AM
Those were only the 89-94 v6
It would run cold (allmost no heat) if it was stuck open
Nubbs's Avatar
January 6, 2010, 11:22 AM
It wouldnt be leaking if it was a stuck T-stat.
Jiffy Lube and Mechanic can not be used in the same sentence ever!
Playing with toys
N8RIDER's Avatar
January 6, 2010, 11:31 AM
Might be the floor mats, but that's just a guess
Fill it up overflow and find your leak/leaks.
#236
PSN - nate1213
RIP Storm May 29, 2009
  Send a message via AIM to Send a message via AIM to N8RIDER
Noob-alishish
Derby's Avatar
January 6, 2010, 11:37 AM
Its a 93 v6 sorry forgot to mention that
Man hoping it isnt a head gasket cause I dont think I have this skills to do that never touched a toyota before....
Not sure where the leak is coming from I did check oil though and it looks fine, its not milky.
Nubbs's Avatar
January 6, 2010, 11:42 AM
Ok so the coolant isnt in the oil. Is there a puddle on the ground in the morning or any signs of coolant leaking on the block at all?
When the truck is running is there white smoke that comes from the exhaust?
Is the passanger floor board wet and smells like coolant?
How offten do you have to refill it with coolant?
BE ENCOURAGED!
GUZZ's Avatar
Ok so I got it backwards? Couldn't it be stuck shut and he thinks it is leaking because it is overflowing? The only reason I even know this is because I had a similar problem years ago with a Chevy s-10 pickup. Other than that I would suggest the flux capacitor because Cole Trickle taught me about car engines.
noise
static's Avatar
Ayyyyeeeeee, sorry for scaring.....
Need to check where the leak is coming from as that can easily cause the temp to rise. Radiator? hoses? coolant pipes? heater core but that prolly inside leak onto the mats...? If it leaks a significant
Noob-alishish
Derby's Avatar
January 6, 2010, 11:48 AM
Correct no coolant in oil, No puddle I see on the ground when parked
Umm well yeah heres the kicker
When I was coming back from being pulled over (when it started sputtering the temp was fine at this time) then when I took off I would say it was prob white/blueish smoke...
I dont know if the passenger side is wet but my cuz said he smelled coolant (I didnt)
I just refilled it today because my heat wasn't working so I checked it and it was low. Before that I think Shoot over a month and a half Id say.
Nubbs's Avatar
January 6, 2010, 11:55 AM
OK...before you think the worse. I want you to check the truck while it is running and see if it is smoking at all. also check the floor board to see if it is wet.
No signs of leaks isnt a good thing but lets see what else is going on before we jump into things.
Fill it up and drive it around the block untill it gets up to temp. whatch the gauge and if it starts to climb into the red get it parked. Look for any signs of leaking when it is hot and running.
Does the truck have heat when it is full of coolant?
Noob-alishish
Derby's Avatar
January 6, 2010, 11:58 AM
Ok while like idling your asking does it smoke?
I know it smokes a little when I first start it up and then every now and then at random times.
yes I have heat when coolant is good.
Ill drive it here in a little while letting it cool down then going to check the coolant again see if its low or the same.
Ill also check the floor board when I take it for a spin.
Looks like the bonk is about to get fixed since this is getting parked lol
