» Online Users: 563
1 members and 562 guests
davidcycle
Any ASP experts here? I need some help with deleting records using ASP
Noob, 07 600rr
jly2k's Avatar
Any ASP experts here? I need some help with deleting records using ASP - June 18, 2008, 09:37 PM
So, I have an HTML form. User inputs the info, script processes the form and saves the info into an Access database.
Here's the sample: http://novasian.brinkster.net/form.html
Then I have a page that shows all the records in the database. But I want to add an option on this page where the user can delete the record. Ideally, I would want to be able to delete the record by clicking on the name.
Here's the page: http://novasian.brinkster.net/show_records.asp
This is what I have for the "show records" page:
<% @ Language="VBScript" %>
<% Option Explicit %>
<html><head>
<title>Form to database - showing records</title>
</head><body>
Dim connection, recordset
Dim sSQL, sConnString
sSQL="SELECT * FROM Users_tbl"
Set connection = Server.CreateObject("ADODB.connection")
Set recordset = Server.CreateObject("ADODB.Recordset")
sConnString="PROVIDER=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & Server.MapPath("Users.mdb")
Connection.Open sConnString
Recordset.Open sSQL, Connection
Response.Write "<p><u>To delete a record, click on a name</u></p>"
Response.Write "<blockquote>"
Do while Not recordset.eof
Response.Write recordset("name") & " , "
Response.Write recordset("email") & " , "
Response.Write recordset("comments") & "<BR>"
recordset.MoveNext
loop
Response.Write "</blockquote>"
Response.Write "<a href=form.html>Add new record?</a>"
recordset.Close
Set recordset = Nothing
connection.Close
Set connection = Nothing
</body></html>
How can I pass the name as a form parameter to say a "delete_record.asp" page? I'm clueless.
Thanks!
This is the script for deleting the record:
<%@ Language="VBScript" %>
<html><head>
</head><body>
'declare your variables
Dim connection, sSQL, sConnString
sSQL="DELETE * FROM Members_tbl WHERE what do I put here?"
Connection.Execute sSQL
connection.Close
</body></html>
Ninja in Training....
roadrunner78's Avatar
June 18, 2008, 09:45 PM
You can do it the same way you add a record. Basically you want to make those variables that you used to add the record the same as the ones you are using to delete the record. Or if your entries have unique ID then you can do it that way as well.
- Craig
If you don't know go ask yo momma
'04 R1 aka "The Bastard"
  Send a message via AIM to Send a message via Yahoo to roadrunner78 Send a message via AIM to roadrunner78
Noob, 07 600rr
jly2k's Avatar
June 18, 2008, 10:05 PM
It worked. Thanks!!
ADMIN - please delete post
