» Online Users: 522
4 members and 518 guests
davidcycle, GRN96WS6, shiphteey, tonetone
boxing twins
hayabusafiend's Avatar
February 13, 2004, 02:50 PM
I've hit a troubleshooting wall, and I could use some help from the geeks. I'll graciously provide beer to whomever helps the most.
I'm setting up a second DNS server running BIND and it fails to lookup certain hosts, specifically wwws.sun.com (the wwws is not a typo).
Servers:
1) BIND8 on Solaris 2.6 = nslookup SUCCESSFUL for wwws.sun.com
2) DNS on Win2K = nslookup SUCCESSFUL for wwws.sun.com
3) BIND8 on Solaris 2.8 = nslookup 'TIMEOUT' for wwws.sun.com
Details:
Server 1: BIND8 is likely hacked by the previous IT network Nazi. I don't trust the system, so I'm replacing it. Moreover, we don't have a secondary DNS server.
Server 2: Internal DNS/WINS/AD server running SP3.
Server 3: BIND8 is right out of the box from Sun. 2.8 has the latest clusterpatch applied.
Troubleshooting:
a) the only server with a public reverse is #1
b) server #1 is outside the firewall
c) servers #2 & #3 are inside the firewall
d) all internal devices are allowed full outbound IP
e) no port 53 (DNS) traffic is allowed inbound thru the firewall
f) 'nslookup -debug' doesn't tell me much about the timeout on server 3.
g) named.conf below
Anyone run into this before with an out of the box Solaris install?
icebreaker% uname -a
SunOS icebreaker 5.8 Generic_108528-29 sun4u sparc SUNW,Ultra-5_10
icebreaker% cat /etc/named.conf
// nameserver bootfile
options {
directory "/var/named";
pid-file "/var/named/named.pid";
// query-source address * port 53;
allow-transfer {
x.x.x.x;
// prime the cache
zone "." {
type hint;
file "root.cache";
zone "tsi-telsys.com" {
type master;
file "tsi-telsys.zone";
zone "tsitelsys.com" {
type master;
file "tsitelsys.zone";
zone "y.y.y.IN-ADDR.ARPA" {
type master;
file "tsi-telsys.rev";
zone "x.x.x.IN-ADDR.ARPA" {
type master;
file "tsidmz.rev";
zone "localhost" {
type master;
file "local.zone";
zone "0.0.127.IN-ADDR.ARPA" {
type master;
file "local.rev";
logging {
channel xfer-log {
file "/var/tmp/named-xfer.log" versions unlimited size 10m;
print-category yes;
print-severity yes;
print-time yes;
severity info;
// category lame-servers { null; };
category xfer-in { xfer-log; };
category xfer-out { xfer-log; };
category notify { xfer-log; };
// category security { xfer-log; };
// category general { xfer-log; };
// category resolver { xfer-log; };
// category network { xfer-log; };
icebreaker%
-- Chris
BMW R1100s
Happiness Consultant
EduardoSuave's Avatar
February 13, 2004, 03:23 PM
I'm no DNS expert, but I'd start with ruling out physical/network connectivity.
you didn't mention this but since #1 and #2 can resolve wwws.sun.com, you should get an IP for it. use that to ping and traceroute from #3, you said all internal machines have full outbound so that should allow for ICMP in which case, successful pings and traces should eliminate the first three layers from your problem and then you could look more at the configuration of #3.
have you also tried using snoop during the nslookup, ping and traceroute? you should be able to this from the firewall and #3 too to track the nslookup initiated at #3
also, is #3 the new server? just wondering cos you might want to check the FW for a rule that allows TCP/UDP 53 specifically for the DNS servers but denied for others. if #3 is new, it may not be in that ruleset yet. (I've actually seen this).
good luck.
DBR
#135, #47, Vega
Will pay to see this
www.got-one.com
gotone's Avatar
February 20, 2004, 09:32 PM
1st hopefully you found a solution already but, I'm no help I am about as anti *nix as nixxers are anti-MS
but 2nd what ever happened to Techradio on 106 ??... I loved that show...
  Send a message via AIM to Send a message via AIM to gotone
boxing twins
February 21, 2004, 07:17 AM
I didn't solve the problem, but it doesn't matter. That box is an external DNS to answer A & MX queries for my work domain.
Three guesses why I used Solaris instead of Microsoft. Can you say hackers three times fast?
Microsoft: the never ending circle of pain
I hadn't even heard of TechRadio on 106.
-- Chris
BMW R1100s
