» Online Users: 460
2 members and 458 guests
HotRod1200, nootherids
Contour HD1400 ContourGPS & & Contour HD1300
Я - Ребенок Люциферов
vonstallin's Avatar
Exclamation Contour HD1400 ContourGPS & & Contour HD1300 - April 16, 2011, 09:57 PM
ANyone have experience with this camera set up?
Pro Con? good as Go Pro? Worst?
ContourHD ContourGPS 1400 Wearable Camcorder with integrated GPS FREE SHIPPING
I hate how the gopro looks like a big ol box on your bike and rather have something that looks some what integrated into the bike. I want to get two of these and mount them front and back.
The new software supposedly allows up to 32gb memory card and you can get the water tight housing at amazon for
For $28.00 "><font color=For $28.00 " /> For $28.00 ">For $28.00
"><a href=" /> ">
they charge 40 on contours website also with the housing you pretty much can only use the power button and the record button. it says you can only go 10 meters a little over 30 feet here are the specs from the website:
http://store.contour.com/contour-wat...-case-p17.aspx
Specs:
- Only compatible with ContourHD and ContourHD 1080p cameras.
- Compatible up to 10 meters
- Compatible with TRail mounts and/or standard 1/4-20 mounts
Also the waterproof case does not work with the new contour GPS
I have had a friend who took my contour in the water proof case down to 75 feet for about 30 minutes on a dive and it works perfectly
Link to specs:
Contour Hd Spec
Contour GPS Spec
ContourGPS 1080p HD Helmet Cam (GPS & Speed) - 1400 by: Contour - Helmet Camera & Helmet Cam Shop - StuntCams
Contour GPS Video Mapping GPS Camera revolutionizes the way you document your adventures. The Contour GPS allows for hands free video recording in a 1080p camcorder. In addition to full HD recording Contour video, the Contour GPS from Contour has a built-in GPS tracking which monitors your exact location multiple times per second with pinpoint accuracy, allowing you to capture your location, speed, and elevation while shooting HD video! With Contour software, you can watch your video next to an interactive map, which also shows speed and elevation throughout the video, giving it an unmatched feature set for a video camera.
The ContourGPS captures 1080p video with a 135 wide-angle rotating lens with no fish-eye. At only 5.2 ounces, and the TRail system, mounting the GPS Contour and shooting video in the most intense sports is a breeze. You can select between 3 resolutions, 2 frame rates, or a still photo mode.
Specifications for Contour GPS Map Video Camera:
Video FormatsFULL HD - 1080p:1920 x 1080 pixels30 fpsTALL HD - 960p:1920 x 960 pixels30 fpsACTION HD - 720p:1280 x 720 pixels60 fpsORIGINAL HD - 720p:1920 x 720 pixels30 fpsVideoMegapixel:5mp SensorCoded:H.264File type:.movAudioMicrophone:Built-in omni-directional microphone reduces wind noiseAudio Compression:AAC Audio Compression captures full range of soundLens135 Wide Angle:960p, 720pPhoto 110:1080pMemoryType:Removable MicroSDCapacity:32GB (2GB included)Storyteller AppCompatible with:
  • Mac (10.5, 10.6)
  • Windows (XP, Vista, 7)
Videos transfer:via USB 2.0Battery & PowerBattery Type:Removable Lithium-IonRecord Time:Up to 3Charge via:USB to computer (charger sold separately)Charge time:3 hoursRecommended use with:CONTOUR chargerBodyWeight:5.3oz (150g)Dimensions:95mm x 34mm x 58mm
Features of ContourGPS Tracking Video Camera:
  • Built-in GPS receiver
  • Time To First Fix using AssistNow Service
  • Dual alignment lasers
  • Water Resistant Aluminum Shell
  • TRail Mount System
  • Full HD 1080p (1920 x1080 @ 30 fps): to capture those awesome moments in the highest resolution available.
  • Tall HD 960p (1280 x 960 @ 30fps): for those sports like surfing that are better suited to a taller image.
  • Action HD 720p (1280 x 720 @ 60 fps): when frame rate is more important than resolution. The perfect setting to capture the fastest action. It reduces blur and rolling shutter effect.
  • Contour 720p (1280 x 720 @30 fps): When space on your card is at a premium and you need to record that last epic adventure. This setting takes it easy on your memory.
  • Still Photo: When you want to freeze frame the action, the photo mode is your perfect shot. You can pick from 6 rates (1, 2, 5, 10, 30, or 60 sec) to best capture that moment.
Package Contents:
  • ContourGPS Camera
  • MicroSD Card (2GB)
  • Flat Surface Mount
  • Goggle Mount
  • Rechargeable Battery (up to 3hrs)
  • USB Cable
The Nightmare of Summit Point
WERA Nov# 325 / CCS # 326
Get Tarded!
Tarded Jake's Avatar
April 16, 2011, 11:16 PM
I bought the contour1080 because of weight, and I like the contrast better than the go pro.
The fact you can use the gps model with a smart phone to adjust settings is amazing, with the 1080HD I travel with a net book on long trips for adjustments.
Footage with the waterproof case on in my opinion looks far better than the go pro.
My only beef is my lasers are not aligned properly so you need to play with it a bit to figure out how far off it is.
I used a goggle mount for this clip.
This was as sticky mount.
Goggle
Night
08 Dizzzer SM
98 KLR 650
Get Tarded!
April 16, 2011, 11:17 PM
Dusk
08 Dizzzer SM
98 KLR 650
Silence... I keeeel you
drnknmnky13's Avatar
April 17, 2011, 07:53 AM
I have the 1080 with the waterproof case. Works great. I actually mount to my helmet in the case as it muffles a good deal of the wind noise when riding. Used it on my last scuba trip at about 40 feet with zero issues:
Welcome to Facebook - Log In, Sign Up or Learn More
Ehh. It's on Facebook and I can't seem to embed. Von it's on my FB page under videos.
Then again... That's just me.
And now...The dancing Banana:
Traction Control
Tecknojoe's Avatar
April 17, 2011, 10:20 AM
Von, contact budda about that camera
KTM RC8R
KTM RC390 race
Yamaha R6 race
Honda CRF50 mini
  Send a message via AIM to Send a message via AIM to Tecknojoe
tiblot's Avatar
April 17, 2011, 10:41 AM
I dunno about you but ContourHD GPS looks like a winner to me.
Contour >> ContourGPS >> GPS Video Camera and HD Helmet Cam
Badass tracks location and speed via GPS. Even bluetooth to your iphone for visual output. Although they charge $30 for the add on
2008 Ninja 250r
2006 GSXR-600
  Send a message via AIM to Send a message via AIM to tiblot
Derpetologist
April 17, 2011, 10:46 AM
A lot of people say wind noise is an issue with the Contours, although perhaps not so much with the waterproof case on... anybody know?
tiblot's Avatar
April 17, 2011, 10:49 AM
Dunno, but Jake's videos above didnt have too much wind noise issue.
2008 Ninja 250r
2006 GSXR-600
vonstallin's Avatar
April 17, 2011, 12:39 PM
I might start out with one of them test it then see about a second one.
I didnt know buddha delt in this..thanks Joe.
imz happy
Ill check your page out Chris
Derpetologist
April 17, 2011, 12:49 PM
I wish it was possible to swap between the GoPro's wide angle and the Contour's standard lens at will without needing 2 cams!
Get Tarded!
April 17, 2011, 04:37 PM
Ditto that was without case, it is very easy to mod the case and add a switchable external mic.... or just put foam over the mic hole.
08 Dizzzer SM
98 KLR 650
I'm a llama again!
Slider's Avatar
April 17, 2011, 04:46 PM
Looks awesome I know the TheEvilTwin just got one.
April 17, 2011, 04:52 PM
I got the ContourHD 1080p for snowboarding. For snowboarding its hard to get the lighting dialed in. What are you guys using for motorcycle mounts?
09 ZX6R
Playing in the dirt
jar944's Avatar
April 17, 2011, 05:31 PM
contour 1080 (from buddah) recorded @ 720x30fps.
click on HD
KTMs and Yamahas
The last urrbendah
Stillie's Avatar
April 17, 2011, 07:39 PM
All of my allsports vids are shot with a contour. Just search Stillie and allsports on YouTube.
13 KTM 200 XC-W
15 KTM 350 XC-F
Tags
filming deep penetration
