» Online Users: 542
0 members and 542 guests
Gearing and Stock.
Я - Ребенок Люциферов
vonstallin's Avatar
Exclamation Gearing and Stock. - June 15, 2016, 08:47 PM
Quick Gearing question.
will the bike feel different or will there be any difference at all if you change the stock gearing and in essence make it mathmatically the same stock gearing?
Here is what I mean.
If your start with:
Front sprocket = 17th
Rear sprocket = 40th
and change it to
Front sprocket = 16th
Rear sprocket = 38th
We all know going down 1 tooth in the FRONT is equivalent to going up 2.89 (3th) in the rear.
since I am installing a taller tire (5mm) the extra tooth should compensate right?
over view
OEM 17f /40r
NEW 16f/38r (-1f/12r)
Should equal the same roughly mathematically...but by having a smaller front sprocket....and smaller rear sprocket will the throttle feel different or gas millage end up different?
The Nightmare of Summit Point
WERA Nov# 325 / CCS # 326
June 15, 2016, 09:00 PM
It will feel the same.
But your chain will wear faster with the smaller front sprocket.
And you will have a bit more rear squat under acceleration with the larger rear sprocket ( will be changing the geometry slightly).
vonstallin's Avatar
June 16, 2016, 01:31 AM
ah ok...
The rear sprocket will be smaller than OEM.
going from Rear 40 to Rear 38.
June 16, 2016, 11:15 AM
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
You can calculate your final drive ratio.
