» Online Users: 569
4 members and 565 guests
2blueyam, nootherids, Scot, tonetone
GMC Hookups? Yukon problems
GMC Hookups? Yukon problems - September 10, 2009, 04:57 PM
I am pretty sure something shorted on my Yukon. My trailer's running lights do not work at all. Turn signals, hazards and brake lights do work.
I tested the connections from the 7 pin plug on my Yukon and I have no power to the running lights. I've checked 2 of the 3 main fuse boxes inside my Yukon for a blown fuse and so far haven't found one.
Is there a special fuse box in the Yukon that I haven't found yet? Then I also found:
http://www.bestliquidations.com/GM10383321.htm
then:
http://www.wmi.org/bassfish/bassboar...ing/T13345.htm
TPG Bannings: III
September 10, 2009, 05:02 PM
Is the harness factory or is it using a T connector of some kind for lights?
Either way the trailer harness a lot of times uses the same circuit as the trucks running lights, so the same fuse. If your parking lights(running lights) are working on your truck, your harness should be feeding fine as well. There is a bad connection somewhere.
Troubleshooting trailer lights has probably caused many suicides, brake controllers, even more.
TPG Bannings: III
September 10, 2009, 05:06 PM
On second thought, just read that thread where they are talking about seperate fuses if its a factory harness, so keep looking I suppose?
