» Online Users: 580
4 members and 576 guests
davidcycle, RideUniverse, Scot, Slider
Heated Seat Swap Ford Focus St need electrical help
bluhokie12's Avatar
Heated Seat Swap Ford Focus St need electrical help - December 9, 2014, 04:43 PM
So I swapped seats from a non power seat to a powered seat with heat. Has the heat infrastructure and harness as well as connecting cables on the seat side.
What I need as anyone who knows of shops or buddies who could cleanly help for $ to get the seats power/controls on the car side so that the car would function like it came from factory with heated seats and their controls.
Anyone have a recommendation?
drt_Jumper's Avatar
December 9, 2014, 06:37 PM
I have the same car (st with heated leather recaros) assuming you have a non heated seat st you will have all the wiring for the seats. All you should need is the dual switch out of a junk st 3 to install in your center console. You may have to cut out a whole for the center console. If you can wait a week you can being it to my place and we can work on it with my car as a reference point. I can do all the wiring and such if need be. But having that 5 position switch is going to be essential as the seat is not just a on off type seat like in my euro spec svt focus.
bluhokie12's Avatar
December 9, 2014, 07:58 PM
Yeah, the question is, is the wiring already in place so that its just cut a hole out for the controls and hook it up to the control harness, or will I need to run from seat harness all the way to switch harness.
drt_Jumper's Avatar
December 9, 2014, 08:19 PM
Every st I have torn into has had the same wiring harness. So yours should have the wiring.
need more knee down
LVegaJr's Avatar
December 9, 2014, 08:48 PM
Ford lays the same wiring into all their vehicles, no matter if they have all the options to use it all. This ultimately saves them money since the time it would take to specifically lay out all the wiring needed would be $$$$$$. For instance, F150s are all pre-wiried for the rear camera. If your truck didnt have one, you just buy the rearview mirror with the screen and the camera, both come with pigtails and the main harness is already in the truck.
I'd say you could go to Ford parts and order a ST console with the slot for the heater switch and the actual switch and just plug and play it all in. The seats you got probably already have the associated pigtails needed to plug into the car's main harness.
~Lou
  Send a message via AIM to Send a message via Yahoo to LVegaJr Send a message via AIM to LVegaJr Send a message via Skype™ to LVegaJr
