» Online Users: 571
5 members and 566 guests
GRN96WS6, Sal_the_man, Slider, tonetone, TonUp
Help me fix my pro-street Cobra Jet engine
Leoallafila's Avatar
Help me fix my pro-street Cobra Jet engine - March 16, 2012, 03:23 PM
Here is what's up...
I recently bought a sleeper car with a built 429 Cobra Jet (bored and stroked), fuel injected and all the good stuff. It's got less than 3k since rebuild, and the mother...effer... Enginetech head gasket on the driver's side has started leaking (coolant level drops everytime I drive, no water in engine oil, low compression on cylinders 7 and 8, high pressure in cooling system in minutes). The guys over at Legend Motorworks in Alexandria (only shop in the area that seems they would know how to work on this kind of engine) said they would change both head gaskets for $500 + parts. That is a great price and totally affordable. However I would like to be an active part of the job, to learn more about V8's, but I don't think they would let me assist while they work (understandably too).
I have experience on motorcycle engines and European car engines, but none on an old-school V8 and I just like doing things myself and learning how to do so. In theory it should all be much simpler, but the truth is I would much rather have someone around that knows exactly what to do and learn, than to make mistakes on a 500hp engine... I'm willing to pay, but I want to be part of it to learn more about how to work on these engines. I have a garage and a decent selection of tools (I'll buy whatever is missing).
Any takers?
2006 BMW R1200ST
2003 BMW K1200GT (Current)
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2005 Aprilia RSVR Factory
2001 Triumph Tiger 955i
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Suzuki GSX-1100R
1991 Honda Africa Twin 750
2004 Aprilia RSVR Factory
1990 Aprilia Pegaso 125
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
March 16, 2012, 03:26 PM
Do you know that the deck on the head and/or block is good?
I watch a LOT of gay porn.
  Send a message via AIM to Send a message via AIM to HenryW
Give me the Ban Button!
Nubbs's Avatar
March 16, 2012, 03:29 PM
He will not know that until he gets it apart. If it is a cast iron block it should be ok. It is the heads he will have to worry about.
March 16, 2012, 03:49 PM
Block and heads had been machined and leveled prior to reassembly, I seriously hope it's just a faulty gasket.
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
I'm a llama again!
Slider's Avatar
March 16, 2012, 03:53 PM
No fluid went into the engine right?
March 16, 2012, 04:05 PM
Nope, changed oil and filter to make sure and there is ZERO contamination.
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
March 16, 2012, 04:08 PM
Here is what I have observed so far:
- the engine runs like a champ at a constant 190 degrees
- gives no smoke/vapor ever (cold start, hot start, idling, revving, heavy load, hard acceleration... Nothing...).
- no clear smell of coolant in exhaust
- no water in the engine oil
- no visible leaks anywhere
- coolant level drops by inches every time I drive
- top radiator hose becomes hard when engine is hot suggesting high pressure in the system
- Spark plug number 7 is sort of corroded with dark grey deposits
- Compression on 1 to 4 is good, 5 good, 6 good, 7 a little low, 8 half of the good ones
- reacting liquid test suggests exhaust gasses are present in coolant when engine is running.
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
March 16, 2012, 04:09 PM
Actually I did observe some smoke today when idling some minutes after starting the car, but as it warms up it goes away, might just be condensation on exhaust system, not sure
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
Nubbs's Avatar
March 17, 2012, 07:55 AM
Small amounts of coolant can burn off with out giving many signs of actual coolant burning. Do you have an air compresser? Might want to do a leak down test before pulling the heads off so that you at least have an Idea of where it is leaking from. I would put money on the #7 & 8 holes are leaking through a coolant passage.
Unfortunately just because the heads were milled before they were installed doesn't mean they are still straight.
I sent you my number in a PM. Text me and we can work something out. Good news is it sounds like you only have to pull one head.
125cc weedwacker
BBR6's Avatar
March 17, 2012, 11:07 AM
Bad news is you still have to pull damn near everything off the top of the engine.
If you are concerned about the quality of the head gaskets, it may be worth pulling both heads and replacing them for piece of mind since you're going to be in it that far anyway.
1998 Honda RS125 -Living room show piece
March 17, 2012, 11:22 AM
I was thinking that.... it's 8 bolts more...
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
poz top looking 4 neg bot
Slow's Avatar
March 17, 2012, 12:19 PM
you need this to fix the compression problem:
jk
horsepower is how fast you hit the wall, torque is how far you take the wall with you
March 17, 2012, 12:28 PM
I was like "wtf man, really?" lol
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
March 18, 2012, 10:40 PM
Great day today: met Dubbs (thanks dude!) and found out there was no problem with the car's engine but just a freak leak from one of the hoses, whoo-hoo!!!
2006 BMW R1200ST
1997 Aprilia RS250
1998 BMW K1200RS
2000 Ducati 998
1998 Pegaso 650
1999 Ducati 996S
2004 BMW R1150R
2002 Yamaha FZ1
2006 Buell Ulysses
1991 Ducati 888
1995 Honda CR250
1996 Aprilia RS125
1995 Aprilia Sr 50
1984 Kram-it 50
Nubbs's Avatar
March 19, 2012, 07:24 AM
Good times yesterday. Im glad it turned out to be something easy to fix.
