» Online Users: 613
1 members and 612 guests
tonetone
IT Help Needed- tuvtstq.dll
IT Help Needed- tuvtstq.dll - December 13, 2007, 08:25 PM
I'm not having any success getting rid of this file because I don't know what the hell is using it, so I can't shut it down.
Apparently it causes IE to openly automatically to various sites.
It was me.
Widow Maker's Avatar
December 13, 2007, 08:31 PM
I hate that shit. It makes me not want to download anything. Ask Ghostryder.
Mohawk Ryderz Road Captain
www.MohawkRyderz.com
"We drop sukaz!"
December 13, 2007, 08:43 PM
get a MAC...end of story
stupid IE double post...point illustrated
singin sweet home alabama
DvlsAdvc8's Avatar
December 13, 2007, 09:01 PM
There are several trojans that do this, try online scan from: http://www.pandasoftware.com/activescan/ or http://housecall.trendmicro.com/
Do you have AV on this computer? Is it up to date?
Sometimes you can just do a system restore - if you have a system restore point available that is prior to infection. Not always, but occassionally.
December 13, 2007, 09:02 PM
not too much shows up from a google search but a couple things popped up. May have something to do with Toolbar 888, more than likely spyware located under c\windows\system32\tuvtstq.dll
Have you tried to run spybot, windows defender, or something similar? Make sure it checks the registry as well.
Katie 135
December 13, 2007, 09:35 PM
may sounds silly but have you tried to remove it in safe mode?
2018 XSR700
2019 Janus Halcyon
December 13, 2007, 09:42 PM
I'm running AVG for AV, updated today and it's caught a bunch of stuff.
It started with some spyguardpro.com window popped up and stuff started downloading. I killed my wireless card asap.
tuvtstq.dll is in C:\WINDOWS\system32\ That's where some other crap had been. The date and time is within a few minutes of what the other files had. Those were in various folders within the Temp folder.
Some other files that I think are related are core.sys and core.cache.dsk in C:\WINDOWS\system32\drivers. They have create/mod times around the same time too.
I can't delete any of these.
I've looked up "spyguardpro.com popup" with Google and found some similiar cases but nothing about tuvtstq.dll
NOM NOM NOM
Dragon's Avatar
December 13, 2007, 09:47 PM
simple...format it
Go Team Venture!!!
Jedi's Avatar
December 13, 2007, 09:56 PM
Backup your registry:
  • Start
  • Run
  • Type the following to the box and hit Ok: regedit
  • A window opens, click on File
  • Choose Export form the menu
  • Change the save location to C:\
  • Give the filename, RegBackUp
  • Make sure that the filetype is set to Registryfiles (*.reg)
  • Click on Save and Close the window
Open Notepad (NOT WORDPAD!) and copy the following lines from the quote box below into a new document, leaving a blank line at the end. (don't forget to copy and paste the word REGEDIT4) :
REGEDIT4
[HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\explorer\shellexecutehooks]
"{71B45E0D-2FD2-4EA6-91FD-A0AFEB696BD0}"=-
Make sure there are NO blank lines before REGEDIT4
Make sure there IS one blank line at the end of the file.
Save the document to your desktop as Fix.reg and filetype: All Files
Go to your desktop and double click on the file to run Fix.reg and when it asks you if you want to merge the contents to the registry, click yes/ok.
Restart your computer to the safe mode:
  • Restart your computer
  • Start tapping the F8 key when the computer restarts.
  • When the start menu opens, choose Safe mode
  • Press Enter. The computer then begins to start in Safe mode.
Go to the My Computer and delete the following files (if present):
C:\WINDOWS\system32\ddaya.dll
C:\WINDOWS\system32\ssqrs.dll
C:\WINDOWS\system32\wvuvsqq.dll
C:\WINDOWS\system32\sttss.bak2
C:\WINDOWS\system32\sttss.bak1
C:\WINDOWS\system32\tuvtstq.dll
Go to the My Computer and delete the following folders (if present):
C:\WINDOWS\iofo
C:\Program Files\VSAdd-in
Restart normally. Let me know how things are running.
"Whore Force One" pilot
The Whitest of White Boys
Not 40 yet!
Now with a TBSP of love
Spiritnblk's Avatar
December 13, 2007, 10:41 PM
  • Start
  • Run
REGEDIT4
C:\WINDOWS\iofo
I was gonna say the exact same thing
/\ should work
December 14, 2007, 06:59 AM
None of the suggestions has worked. It still won't let me delete it.
tuvtstq.dll is still the only thing that seems to be the problem.
What happens is when I'm browsing in Firefox I'll click a link, like on this forum and IE will open. The same sites have opened several times.
Triple Secks
Abrasive's Avatar
December 14, 2007, 07:39 AM
I had a similar issue a year or so ago on my wifes pc.
I *think* i used this:
http://www.free-codecs.com/guides/Ho...d_AX_files.htm
it looks very familiar, but i cant be 100% sure that is what i used due to time passed.
Good luck!
I believe i can see the future;
because everyday i repeat the
same routine.
Retired to most ...
JohnnySpeed1KRR's Avatar
December 14, 2007, 08:03 AM
You are going to have to manually go in and remove all it's components.
Run a search for the file or name ..... every single thing that shows up related to that file gets deleted one at a time. You just have to make sure you are killing files and file links to THAT program since most of what you are going to find will be in system32 files and you don't wanna be in there just deleting shit!!
Lemme know if you need some help doing it. I had to do the same thing for a couple of the computers here at FLC.
December 14, 2007, 09:41 AM
remove IE...
What jedi posted is basically what you need to do, go in in safe mode and delete the dll, backing up your registry is a must.
