» Online Users: 546
5 members and 541 guests
HenryW, nootherids, Sal_the_man, TonUp, Triple X
Javascript Help (Coding Question)
Resident Rodent
Magic-Rat's Avatar
Question Javascript Help (Coding Question) - August 2, 2009, 10:04 PM
Hi all,
I'm a Javascript noob and am wrestling with a problem ...
I have several websites where I use a Javascript function to display a "loading.gif" while the page loads. It works great.
Example at my website: http://www.magicratproductions.com
Well, I built a new page for a different site and used some graphics with rollover functions on my buttons (when you hover over a button, the text of the button changes).
The problem is that my loading function and my rollover functions are incompatible.
Can someone give me some advice on how I might deconflict them? Would greatly appreciate it.
Code below:
<head>
<script type="text/JavaScript">
window.onload = function(){
document.getElementById('loading').innerHTML = '';
if(document.getElementById('overallcontainer').sty le.visibility ==
"visible"){
document.getElementById('overallcontainer').style. visibility = "hidden";
}else{
document.getElementById('overallcontainer').style. visibility = "visible";
</script>
<script type="text/javascript">
function newImage(arg) {
if (document.images) {
rslt = new Image();
rslt.src = arg;
return rslt;
function changeImages() {
if (document.images && (preloadFlag == true)) {
for (var i=0; i<changeImages.arguments.length; i+=2) {
document[changeImages.arguments[i]].src =
changeImages.arguments[i+1];
var preloadFlag = false;
function preloadImages() {
home_01_over = newImage("images/home_01-over.gif");
preloadFlag = true;
</script>
</head>
<body onload="preloadImages();">
<center>
<div id="loading" ><img src="loading.gif" border=0></div>
</center>
<div id="overallcontainer">
... all the page content goes here ...
</div> <!--End overallcontainer -->
</body>
</html>
- Rat
"Ride to the sound of the guns."
Out of Action
SLOride's Avatar
August 2, 2009, 10:22 PM
<head>
function() startup() {
removeLoadingImage();
preloadImages();
function() removeLoadingImage() {
"visible"){
}else{
</script>
rslt = new Image();
rslt.src = arg;
return rslt;
preloadFlag = true;
</script>
</head>
<body onload="startup();">
<center>
</center>
Maybe that above.. just change the first window.onload into a function.
Then wrap the calling of that function (which I believe serves to hide the loading.gif?) and the preload images at the same time.
I'll look at this again in the morning after some sleep and actually try it
*sigh*
  Send a message via AIM to Send a message via AIM to SLOride
SaS
Sas pronounced Sauce.
SaS's Avatar
August 2, 2009, 10:37 PM
incompatible in what way? Describe what is happening in more detail.
I came I saw I shat mysef
jron's Avatar
August 2, 2009, 11:31 PM
Also.. What browser are you using? IE ?
-john
wera, ccs - novice # 979 - sv650
Aprilia Falco (sold), Gs500 (sold), KTM300 (sold)
"I'll believe corporations are people when Texas executes one of them."
Separation of Corp. And State!
R.I.P Alex Lyskawa - My heart will never heal from your passing.
  MySpace.com Page Send a message via AIM to Send a message via AIM to jron
Site Owner
ClemsonJeeper's Avatar
August 2, 2009, 11:41 PM
You have two onloads. There can be only one.
The first is the
at the top, the later is:
So the fix would be to take all the code from window.onload = function {
<cut this>
and put it in your preloadimages() function. Then delete the window.onload= ... block.
Katie #135.
B: that sounds odd
Resident Rodent
Magic-Rat's Avatar
August 3, 2009, 05:34 AM
Ah. Well, as is, the loading.gif displays ... forever. It just hangs.
If I romove the onload="preloadImages();" from the BODY tag, then the loading.gif works fine ... but, it then the rollovers for the buttons don't work.
If I remove the entire window.onload script, then of course the loading.gif does not display ... but the rollovers work fine.
I'll try some of the things you all recommend when I get home tonight.
Thks!
- Rat
Resident Rodent
Magic-Rat's Avatar
August 3, 2009, 05:40 AM
I tried sloride's suggestion. Has same result as the original.
I've zipped the contents if anybody wants to d/l and take a look. It's a very simple site.
Here: http://flandersland.tzo.com/bogus/bettysriverroad.zip
Hooah.
- Rat
Resident Rodent
Magic-Rat's Avatar
August 3, 2009, 05:42 AM
I'm using Chrome, IE 7, Mozilla, and IE 6. Get same results in all of them.
- Rat
Resident Rodent
Magic-Rat's Avatar
August 3, 2009, 08:14 AM
Jeeper ... your idea worked. I added all the functions to one onload event.
Like this. Works. Thks!
rslt = new Image();
rslt.src = arg;
return rslt;
document[changeImages.arguments[i]].src = changeImages.arguments[i+1];
if(document.getElementById('overallcontainer').sty le.visibility == "visible"){
}else{
preloadFlag = true;
downstairs_01_over = newImage("images/downstairs_01-over.gif");
preloadFlag = true;
adirondacks_01_over = newImage("images/adirondacks_01-over.gif");
preloadFlag = true;
contact_over = newImage("images/contact-over.gif");
preloadFlag = true;
directions_01_over = newImage("images/directions_01-over.gif");
preloadFlag = true;
</script>
- Rat
Site Owner
August 3, 2009, 08:27 AM
cool, glad it works. problem was your second onload definition overrode the first.
Katie #135.
B: that sounds odd
Resident Rodent
Magic-Rat's Avatar
August 3, 2009, 08:51 AM
Yup. Here's the finished product:
http://www.magicratproductions.com/bettysriverroad/
- Rat
Out of Action
SLOride's Avatar
August 3, 2009, 09:04 AM
Interesting.. obviously it ws the 2 onloads.. but I figured if I made the 1 onload call a function.. that just called both functions.. that it would have worked.
Not sure why my solution didn't pan out
*sigh*
Out of Action
SLOride's Avatar
August 3, 2009, 09:06 AM
BTW, to add on. Magic - you should look at things like jQuery/jQuery UI.. or prototype/scriptaculous.
Just some libraries that simplify handling onloads & UI updates.. all of which will work in any browser.
I even have some books you can borrow if you'd like.
*sigh*
Site Owner
August 3, 2009, 09:15 AM
That would have worked fine, but in your code:
preloadImages();
function() startup() and
is not valid javascript.. would probably result in parse errors.
typos ;D
Katie #135.
B: that sounds odd
Out of Action
SLOride's Avatar
August 3, 2009, 09:38 AM
preloadImages();
typos ;D
Ahh yeah.. drats.. that is what painkillers and no sleep will get me.
BTW, did people look at it all in IE 7? I found the load gif to not be centered in IE7.. but it looks good in chrome/safari 4 and FF3.5
*sigh*
