» Online Users: 539
1 members and 538 guests
GRN96WS6
Microsoft Excel Solver Help
Macon663's Avatar
Microsoft Excel Solver Help - November 8, 2012, 12:28 PM
I need some help w/ a spreadsheet I'm trying to create. Trying to use solver to answer some questions I need it to but can't get it to work right.
Anyone out there an excel wizard?
I don't think I'm using a linear equation which may be part of the issue. But I can't tell.
Im Always Down to Ride
bds120's Avatar
November 8, 2012, 12:31 PM
Man I been doing a lot of solver...whats up?
Speed kills, ride a Yamaha!
Macon663's Avatar
November 8, 2012, 12:44 PM
So, I'm using solver for fantasy basketball. I have a budget of 100 dollars.
I'm trying to get solver to tell me which player for each position is going to get me the most points for the budget I have.
So I have a pg, sg, sf, pf, and center positions. Players have different values, obviously good players cost more. But I can project how many points each player will get me on any given day. But I want to get solver to tell me, based on my projections of how many points I think each player will get me, what the best combination of players (pg, sg, sf, pf, c) is given the constraint of my budget.
Make sense? Is that possible?
bds120's Avatar
November 8, 2012, 01:00 PM
So It makes sense.
But you have to have the defined differences in costs of the different players. That is the only way it will choose the best combination. Else given that you have a 100, it is going to split them evenly and give each 20. So you have to state that. As well, this would not be linear because I don't see how this could fit the y=mb + b for linear slope.
Macon663's Avatar
November 8, 2012, 01:08 PM
Right, so I have an excel file full of all the different pg, sg, sf etc in the league. Each one has a different cost and each one has a different projected points value.
Its definitely not linear.
I want solver to recognize that player A costs 10 dollars, plays the PG position and will get me a projected 10 points. Player B could be 15 dollars, play the SF position and will get me a projected 8 points.
But theres 150 players or so total to choose from.
I hate Hybrid drivers
david636's Avatar
November 8, 2012, 01:14 PM
SUPERBITCHIN'
{SALVA}'s Avatar
November 8, 2012, 01:17 PM
you need excel to do that shit? pen and paper man...maybe an abacus. easy.
E che cazzo!
bds120's Avatar
November 8, 2012, 02:27 PM
Ok so you would definitely set your changing cells to be the different postions and then you need to set the different totals to ensure that they are <= 100.
From there it will give you the outcome. I will throw up a sample in a bit when I get some free time.
nootherids's Avatar
November 8, 2012, 02:55 PM
I did a spreadsheet like this once. It said...
If I sleep with ___ women then that will yield a ___% probability of contracting ___ STD's.
Turned out that the more women the more STD's but the lower the probability. Hmmm, maybe I wrote the formula wrong. Be back later, I need to apply some ointment again.
Chris's Avatar
November 8, 2012, 09:06 PM
so you want to calculate out the points of the players and based upon that pool of players, select the highest in each position that will still keep you below $100?
"I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you fuck with me, I'll kill you all." -MG James Mattis, Iraq 2003
Ruining .net one post at a time
bds120's Avatar
November 9, 2012, 05:08 AM
No he is trying to calculate how many of each player he can buy with the allotted 100 he has given that each player can give him points.
So basically he wants to get the most of each position that will give him the most points without exceeding his 100 constraint.
Chris's Avatar
November 9, 2012, 05:14 AM
This would probably go easier if i had ever played fantasy football
Do you have a draft excel doc of the players or anything youve already made?
bds120's Avatar
November 9, 2012, 05:42 AM
He was sending it to my personal email..
He might as well post it up.
Macon663's Avatar
November 9, 2012, 07:33 AM
I got it figured out. It literally takes my computer 5 minutes to solve the problem.
BDS hit the nail on the head w/ the intent.
bds120's Avatar
November 9, 2012, 07:44 AM
Sweet. Its usually the backend formula behind the output cell and the formula/data in connection to the changing cells. Anyways...glad you got it. All I am/have been doing lately is using Solver, SolverTable, and the @Risk software to do linear programming models. Had to use stupid program called LINDO also to generate the actual written form then it would output all the data and sensitivity analysis.
Glad it worked for ya
