» Online Users: 523
3 members and 520 guests
boomboom929, nootherids, Sal_the_man
Need computer help
Don't ask me,I'm Canadian
C2H5OH's Avatar
Need computer help - August 28, 2008, 04:02 PM
I'll only call Toshiba/Microsoft as a last ditch resort.I hate customer service.
So here's my problem.I bought a Toshiba Satellite laptop a month ago.It has Vista.From the very first day,every time I turn off my laptop,it turn's off,then a few minutes later it turn's back on by itself.I used The Google and all the problems I found were people shutting down and getting a blue screen.My laptop will totally shut down.I read how some people thought it was from add-ons like a wireless mouse,as I have,but I didn't add the mouse until the next day,so I eliminated that.All drivers are up to date,etc.
Any ideas?
August 28, 2008, 04:12 PM
check the timers and stuff...you can set laptops to turn on/off at certain times..just the same as you can set programs to run at certain times. IE antivirus scan programs.
but that doesn't explain why it happens EVERY time....check to make sure ur on/off button isn't stuck or something.
let the battery run completely dead...then when it shuts off on it's own...plug it in. If it turns on...something is wrong with your switch.
PM Ceaton - he works for geeks on call and drives that dumbass beetle car hahaha
...ugh..the "blue screen of death" = not cool - at that point..might as well dump and start over with the "your shit is screwed" disc.
FASTER
JUSTGO's Avatar
August 28, 2008, 04:30 PM
What happens if you do not do a shut down and just hold the button down until it turns all the way off and release the button. Does it turn back on then?
After it shuts down and restarts itself do you then just tell it to shut down again? Does it do the same thing all over again?
So the very first time you shut it down before making any changes it did the automatic restart? Sounds like a hardware issue and not a software issue. Toshiba will probably be the only one that can help you with that for free atleast cause it is sounds like a faulty part.
August 28, 2008, 04:51 PM
Too much redtube.com
System board/fan.
I'm on bberry right now too lazy to read all of it.
Vroooom Vroooom
vohra1's Avatar
August 28, 2008, 04:57 PM
Does it power back on after a few minutes every time you turn it off....or occasionally?
Try powering it off, and then pulling out the battery. Throw the battery back in after a while..to see if it powers back on.
That should help you figure out if it is a because of a timer or some other hardware related issue.
C2H5OH's Avatar
August 28, 2008, 05:34 PM
It will shut off for good then.Problem is,I spend 15 minutes trying to connect to the internet after I power back up.I unplug my modem and reset the IP several times,so I avoid doing that.
skwidrific's Avatar
August 30, 2008, 10:19 AM
Please delete your WTF folder and your addon folder from your UI folder
2001 GSXR 1000 (The bike that lit the afterburner on the liter class world)
2012 Monster 1100 Evo
2003 Yamaha YZFR6 (track only)
mmm... carbon fiber
Originally Posted by No One Ever
Awesome Prius!
  Send a message via AIM to Send a message via Yahoo to skwidrific Send a message via AIM to skwidrific
SMB
sans motor bike
SMB's Avatar
August 30, 2008, 11:30 AM
Any ideas?
get rid of vista....if not then =
check that when you push the power button that it is not set to hibernate rather than power off....
August 30, 2008, 06:03 PM
Make sure that your nic isn't set to: Allow this device to wake the computer.
BTW - when you go to shut down via the menus what are you selecting? Are you actually clicking on the words 'shut down' (by clicking the arrow to the right of the lock icon) or the power switch icon that puts the machine iinto memory and a low-power state?
also check this:
http://support.microsoft.com/kb/927821
C2H5OH's Avatar
August 30, 2008, 07:16 PM
also check this:
I click shut down.
I went to the Microsoft link.I unchecked "Allow this device to wake the computer"
Crossing my fingers.
August 30, 2008, 07:44 PM
I click shut down.What is a nic?
Network Interface Card.
Go to the Start Button/Control Panel -in the new window if the words Control Panel Home are bold then click on: View Network Status and Tasks
If Classic View is bold then click on: Network and Sharing Center
Now in the left pane of the Network and Sharing Center click on:
Manage Network Connections
In this new window do the following to both Local Area Connection and Wireless Network Connection:
Right click on the above Icon then left click on Properties
In this window you will see a Configure button, click on it and it will open a new window.
Select the Power Management tab.
You want to have the following UNChecked: Allow the computer to turn off this device to save power
If right below that is checked (Allow this device to wake the computer) you may have to check the above box first, then uncheck 'Allow this device to wake the computer', then uncheck to the top box.
Good Luck.
PewPew
NoVaGhost's Avatar
August 30, 2008, 07:49 PM
Any ideas?
trash it and buy a mac
Sounds like hardware is turning it on... a paired cell phone can wake / turn on computer.
R.I.P. Eric "TheIrishGuy"
August 30, 2008, 07:52 PM
I need to try a MAC....
PewPew
NoVaGhost's Avatar
August 30, 2008, 07:56 PM
I swear by them now. I started using them when I started architectural drafting and deisgn back in 2002, will NEVER go back to a microsoft based PC. I've had numerous HP laptops take a and die on me after 8 - 10 months of use, my macbook pro is 2 years and some change in age and still running like new. Only thing that sucks is the batteries for the macbooks only have a lifespan of about a year,
