» Online Users: 525
3 members and 522 guests
fxc3700, nootherids, Sal_the_man
Need help from network programmer dudes - send / rec UDP packets
LooseTooth's Avatar
Need help from network programmer dudes - send / rec UDP packets - October 15, 2009, 04:29 PM
OK, I just found out I have to quickly write a program that is a little out of my range. I usually write programs like A = B + C. This one involves networking
I have to show up at a remote area and have this work. Here is the information I've been given:
-Broadcast some information about my system using UDP/IP
-I'm the client.
-They are the server.
-Both IPs given.
-Their port is given.
I about have my program written. I just have to map my data into the 'datagram' I'll be sending.
My question really is, is there an existing set of software that can decode UDP and display the data on the screen? I want to be able to test it with two computers using the same ports and IPs because all of this is hardcoded.
Or do I have to write another program using the recv() function to test my set-up?
LooseTooth's Avatar
October 15, 2009, 05:18 PM
I found some stuff around here that I can make work. It still would be nice if there was something canned that could do the endian swapping and display the data. That way I have more time to surf .net.
