» Online Users: 494
3 members and 491 guests
'06 R6 rear axle nut won't loosen
donniecs's Avatar
'06 R6 rear axle nut won't loosen - July 17, 2007, 10:32 PM
I was trying to do my first tire change, well at least remove the wheels so I can take them to get new rubber put on. I got the front wheel off without a problem. The rear wheels axle nut doesn't want to loosen.
I've tried that little dinky 32mm wrench in the tool kit until my hand started to hurt. Then I switched to a 12" adjustable wrench which was hard to get a good grip on the nut because it is recessed within the swing arm some. I had all my body weight on the wrench (feet off the ground) and still nothing moved. My last ditch effort for the night was to clamp onto the dinky tool kit wrench with the adjustable wrench for some added leverage. I gave that a few attempts before I feared breaking my hand and called it quits.
The service manual specifies 80ft-lbs of torque for that nut and I had at least 200ft-lbs against it (breakaway torque), I looked at the threads and it is left handed thread. My next idea was to get a pipe that the end of the tool kit wrench would fit in and give that a try (added leverage) or go to Sears and get a 32mm (1 1/4") socket and the biggest breaker bar money can buy (return when I'm done of course). Iím worried that a socket that big doesnít have enough clearance around the nut to fit on it though.
Am I missing an obvious step here or does anybody else have any other suggestions? Thanks in advance for any help!
Charlie
Site Owner
ClemsonJeeper's Avatar
July 17, 2007, 10:48 PM
32mm socket + Bar breaker handle = Win.
Katie #135.
B: that sounds odd
Playing with toys
N8RIDER's Avatar
July 17, 2007, 11:00 PM
+1
That's all you'll need
  Send a message via AIM to Send a message via AIM to N8RIDER
July 17, 2007, 11:04 PM
Whoooaaaa not left hand thread!!!! Try some Permatex lube first. Sometimes a little rust will form and you need a lube to get in there and loosen it up. If that won't work try a little heat from a propane torch. If you really need some help let me know.
Loves Sporking
JPVaccaro's Avatar
July 18, 2007, 12:43 AM
If you invest in a socket, try to find a 6-sided one (Sears probably won't have it in stock). A 12-sider might roll. Good luck!
Johnny V.
CCS & ASRA #67
2006 Suzuki GSX-R1000
2004 Suzuki GSX-R600 (racing)
2004 Aprilia 1000 Mille R (street)
2001 Aprilia 1000 Falco (street)
2001 Suzuki GSX-R600 (racing)
1995 Kawasaki ZX-6E (street and racing)
1986 Yamaha Radian 600
(street)
July 18, 2007, 12:55 AM
Like dodge said, apply heat. My rotors were so tight they may as well been welded onto my chromies, a little heat and they came off like butter.
Retired to most ...
JohnnySpeed1KRR's Avatar
July 18, 2007, 06:43 AM
Ahhh the power of air!!
Rob has it right. 32 socket and a breaker bar. Then you can put some ass behind it.
Repping WPNR is Tennessee
PimpD's Avatar
July 18, 2007, 07:11 AM
+1000000000000 on what rob said...........if it doesnt work...a little heat, and it will come off like nuffin!!
Cause thats how we roll......
July 18, 2007, 07:19 AM
Bring it to a real man, me
July 18, 2007, 07:43 AM
+1
DO NOT use an adjustable wrench on that bolt, you could strip the bolt easily.
Also, have someone hold the bike since it's very easy to lift the rear and possibly knock it off the rear stand.
singin sweet home alabama
DvlsAdvc8's Avatar
July 18, 2007, 07:49 AM
Just make sure you don't break the puller/spacer on the other side of the axle if yours is designed the same way as the R1!!!
July 18, 2007, 08:15 AM
Air or electric impact are very helpful. As JPV said...get a 6 sided impact socket.
July 18, 2007, 08:31 AM
Turn it the other way.
