» Online Users: 531
1 members and 530 guests
davidcycle
2000 R6 leaking....help
Nice & Smooth
prkid424's Avatar
2000 R6 leaking....help - June 26, 2007, 09:23 AM
Like the title says my R6 is leaking, but I have no idea what it is leaking or where from. Some facts:
  • The bike does not leak when parked, meaning I don't come out in the mornings or after work with a puddle of fluid under the bike.
  • The leak only occurs when the bike is moving, not sure if when under acceleration or just when its turned on.
  • The leak is coming ONLY from the left side. The reason I know this is that the top of my left shoe is always "shiny" by the time I get to work, and when I get home. My pants do NOT get any of the fluid on them
  • The bike has not been laid down or anything out of the ordinary happen to it to cause anything to crack or break (meaning coolant reservoir or engine cover)
My thought is that maybe some of the coolant is leaking, since this would evaporate while parked in the lot during the day and in my parking spot at night. I am not sure what other fluids flow through the left hand side of the bike. I can see that one of the hoses connecting to the reservoir is a bit saturated when I'm done riding, but like I said with my foot on the peg, only the top of the shoe, not the pants, gets fluid.
Any suggestions/help.
Thanks
  Send a message via AIM to Send a message via AIM to prkid424
Site Admin
June 26, 2007, 09:31 AM
most likely coolant...double check all the hose clamps.
Nothing here
Madali's Avatar
June 26, 2007, 09:34 AM
So I take it you are running Water Wetter or equivelant? This assumption is based on your statement that it would evaporate.
Check your brake lines at the banjo fittings.
Does the shoe smell like anything other than your nasty foot? Is it a petroleum smell?
Help us help you.
Nothing here
Madali's Avatar
June 26, 2007, 09:48 AM
Also, look for an accumulation of dust sticking to whatever is leaking. Coolant hoses, forks (seals go bad), brake lines, etc.
Nice & Smooth
prkid424's Avatar
June 26, 2007, 09:59 AM
Help us help you.
Just running regular motorcycle coolant- I was assuming that that stuff woudl evaporate. Brake lines run throgh the right hand side dont they..the front ones goes right to the right handlebar from the calipers and the rear run on the right.
No oil or gas smells...from the shoe.
Republicans for Voldemort
hondahawkrider's Avatar
June 26, 2007, 10:04 AM
have you checked your brake / clutch fluid reserviors - and monitor the levels...
If the bike doesn't drip when you let it run while stationary - I would suspect it's one of those two items as they wont be engaged at the time... just my guess. Regular coolant would be more slimy to the touch...
-Jason
DAMN Rider DAMN Rider
Nothing here
Madali's Avatar
June 26, 2007, 10:17 AM
True on the right side for brake lines resevoir and controls, but don't you have dual front discs? Or did you convert to a single front disc? If not then check the fitting near the left front disc and follow the line up. It could drip from there.
Retired to most ...
JohnnySpeed1KRR's Avatar
June 26, 2007, 11:26 AM
What makes you say it only happens when the bike is moving? Dos the leaked fluid have ANY color to it?
Nice & Smooth
prkid424's Avatar
June 27, 2007, 09:55 AM
I am only assuming that it is happening when the bike is moving becasue there are not spills where I park the bike and I let it warm up for like 7-10 minutes every AM and still no spills on the pavement. I can't really tell if the fluid has any color...
PewPew
NoVaGhost's Avatar
June 27, 2007, 10:04 AM
My guess would be a leak in the coolant system, the pressure that builds when you run the bike is causing it to leak while running. I had an similar issue with my TL1000R. Turn the bike on, it would warm up to running temp and coolant would leak out. I'd get the seal for your radiator cap checked along with all the hose lines.
EDIT: Is it a heavy leak? If it's loosing a fair amount of this unknown liquid then you could also mark your coolant resivor and keep checking to see if it drops. The coolant should have a color to it though..
R.I.P. Eric "TheIrishGuy"
Nice & Smooth
prkid424's Avatar
June 27, 2007, 10:14 AM
Your thoughts and my thoughts parallel. I am taking off all the fairing today in the afternoon to see if I can track down the leak. But my gut feel is the coolant hoses or radiator cap. Leak is not very heavy at all as the bike is not running hot, nor I see a visible drop in fluid (coolant oil, brak)
PewPew
NoVaGhost's Avatar
June 27, 2007, 10:26 AM
good man, trouble shooting it yourself!
on a more serious note, that's exactly the right course of action for now. Just focus on one system at a time and go down the list ( I weight my suspicions on the coolant however )
If that yeilds not favorable results I'd move on to the brake lines.
Also, what side is the leak comming from? I know you said it was leaking on your shoe / boot but I didn't see if you sid what side.
Nice & Smooth
prkid424's Avatar
June 27, 2007, 10:34 AM
3rd bullet first post...left shoe. That is why i dont think its oil or brake fluild. All that is on the right hand side. All that is on the left is the coolant and the fuel overflow line, and its not fuel its leaking
Ling Long
YaoMatt's Avatar
June 27, 2007, 10:37 AM
My guess would be coolant.
Also, your overflow is on the left side of the Yamaha.
U
C
Lots of
Asians
PewPew
NoVaGhost's Avatar
June 27, 2007, 10:55 AM
+1 I agree about the coolant, almost certain. Most likely a line, I believe the radiator cap is on the right side so doubt it's the cap seal.
Good luck with your leak hunt, man. keep us updated.
