» Online Users: 523
3 members and 520 guests
2004 triumph daytona speedometer problem
Spectroscopist/adventurer
fireclown's Avatar
2004 triumph daytona speedometer problem - September 19, 2010, 10:57 AM
Every now and then, while riding, my speedometer will flash and read 0 mph, with no increase in mileage. RPM gauge is unaffected. I know that this is a speedo cable issue, and that it's probably loose or something that is causing it to send a nonsense signal to the instrument cluster and causing it to freak out.
The problem is that I can't seem to find the damned cable. I know some other triumphs have had some kind of dealiewhatsit built into the hub. Is this one of those?
Spaceballs is one dumb ass movie. I'm surprised I had to tell you that.
Space's Avatar
September 19, 2010, 05:09 PM
I can't remember if the Daytonas have a speed sensor mounted to the front wheel or in the trans. Check all connectors going in to the trans. Check the connection at the back of the speedo.
Agitator
birdman's Avatar
September 19, 2010, 05:16 PM
It's British, it was never designed to work consistently.
Marc
CCS Amateur #851
2001 Ducati 850RS
2006 SV650 Racebike
2010 CBR1000RR
2009 Nissan GT-R
fireclown's Avatar
September 20, 2010, 09:28 AM
I took a look at the back of the speedometer. Instead of a normal speedo cable I found a single plug full of tiny wires that got wrapped together in a bundle. I got demoralized and put the bike together again. If it's in the transmission, how boned am I?
Tiny Pimpled Genitalia
Bikrsk8r's Avatar
September 20, 2010, 11:24 AM
my '02 has a sensor in the front hub, left side.
many times shops have failed to get it reassembled properly after having the wheel off.
but there is an endemic problem with the speedo.
a dealer flash update to the ecu or (i'm told) reflash yourself using this software: TuneECU_Start
dealer flash fixed mine
!advance the agenda!
Space's Avatar
September 20, 2010, 04:31 PM
Not much about $86. Get it from the dealler you will get it faster and no shipping.
2004 Triumph DAYTONA 600 & 650 OEM Parts, 2004 Triumph DAYTONA 600 & 650 OEM Motorcycle Parts - BikeBandit.com
Check the connector in at the trans or remove the old and clean it first. Sk8r may be be correct about the reflash.
