» Online Users: 558
3 members and 555 guests
davidcycle, Slider, tonetone
2006 Gsxr 600 code flashing.
600cbr's Avatar
2006 Gsxr 600 code flashing. - June 29, 2010, 08:20 AM
I have a 2006 Gsxr with the red light on and a f1 code flashing. If I restart the bike it goes away. only thing ive done to the bike is put a scorpion exhaust on it. Any one have expeirence with this?
Parkin lot pimpin'
EndoSJ3's Avatar
June 29, 2010, 08:27 AM
look at post #6
FI Fault Code List / Dealer Mode Switch : GSXR.com Forum : Suzuki GSX-R Forums
fruta fresca
sara's Avatar
June 29, 2010, 08:34 AM
I have an 08 gsxr 600 that has been doing this sporadically for the past 2 years. Did you happen to fill up with cheap gas, like at a Sheetz or something? I've noticed it only seems to happen when I fill up by the Sheetz at my house. Does your bike shut off once you kick it into first gear? If so, hold the throttle, ride the bike for about 5 minutes and go through all the gears. If you come to a stop, make sure to keep pulling on the throttle so the bike doesn't shut off. Usually the bike will run normally after this and the light goes off. Yeah, doesn't make any sense, but its the only thing I've found that works.
"no me olvides que yo no te olvidare"
June 29, 2010, 08:48 AM
It's the fi code...usually the exhaust valve & or tps needs adjustment.
#1 Machine: Suzuki GS500K2 / Bridgestone package
#2 Machine: BMW G310R / Michelin package - sooooo light and stable it's funny
June 29, 2010, 08:53 AM
Did your bike have a servo valve in the exhaust?
If it did you need to jumper the ECU plug.
My 03 1000 had the same issue.
600cbr's Avatar
June 29, 2010, 09:02 AM
Originally Posted by EndoSJ3 View Post
Mine didnt come with a repacement wheel. HUM???
600cbr's Avatar
June 29, 2010, 09:19 AM
Im not sure if it had a valve or not. How can you tell? It didnt have any pullys attatched to it or wires. It just came right off and I slipped the new one on.
Parkin lot pimpin'
EndoSJ3's Avatar
June 29, 2010, 09:20 AM
I'd say try pulling the negative terminal off the battery for a few mins and re-setting the ECU...might work and its quick to try
June 29, 2010, 09:22 AM
You didn't have one then.
+1 to removing the neg batt cable for a reset.
600cbr's Avatar
June 29, 2010, 09:37 AM
Thanks Ill try that first.
600cbr's Avatar
June 29, 2010, 09:39 AM
bike donst shut off just f1 code runs fine. I only use highest octane i can get. Ill put some injector cleaner in on the next fill up.
June 29, 2010, 10:08 AM
I'd still bet that your bike had an exhaust servo valve.
Did you buy it new?
June 29, 2010, 10:10 AM
Sara, My guess it that you have been getting some water in the gas.
I think it's the Sheetz near your house
Try running some dry-gas through a tankfull.
600cbr's Avatar
June 29, 2010, 10:25 AM
Did you buy it new?
used but it had the stock exhuast on it. I swithed to the Scorpion slip on.
Here we go Steelers :)
Gixxer Ryan's Avatar
June 29, 2010, 01:13 PM
Put the bike in dealer mode and get the code number, look it up and hope it tells you what you need.
