» Online Users: 558
3 members and 555 guests
davidcycle, Slider, tonetone
2006 GSXR600 Power Commander Question
Super Moderator
Scorpion9R's Avatar
2006 GSXR600 Power Commander Question - March 6, 2010, 02:20 PM
Im installing a Power Commander in a 2006 GSXR600 and the instructions are saying for me use a wire tap to tap into the pink/black wire on the Throttle Position Wiring harness...Thats a tight fit! Anyone have any issues with this or tapped into that wire in a different place?
-George Orwell
CCS Amateur #588
Lets Ride!!!
myblue750's Avatar
March 6, 2010, 05:22 PM
Don't use the wire tap. It has a bad connection and will leave you high and dry at a stop light (ask me how I know...) Your best bet is to strip the wire and solder it together. I have not had any troubles since doing that. Good luck.
Go Hokies!!!
2007 GSXR 750 Black/Midnight Blue - sold
Lets Ride!!!
myblue750's Avatar
March 6, 2010, 05:23 PM
Also, the harness that plugs into the TPS comes out so you can more easily do what you need to do. It took me a while to get it off of mine though...
Go Hokies!!!
LooseTooth's Avatar
March 6, 2010, 05:46 PM
Yeah the wire taps are a nightmare. Cut wire. Strip ends. Slide on heat shrink. Solder the three wires together.
unapologetic
Hollywood's Avatar
March 6, 2010, 07:55 PM
this is the correct way. It also will limit the ability for a short to occur at the tap in, hopefully making your PC work a little more reliably. Don't forget to shrink wrap the wiring when you are done to help with moistureproofing.
"ride on #47, ride on"
Super Moderator
Scorpion9R's Avatar
March 6, 2010, 08:42 PM
Originally Posted by Hollywood View Post
this is the correct way. It also will limit the ability for a short to occur at the tap in, hopefully making your PC work a little more reliably. Don't forget to shrink wrap the wiring when you are done to help with moisture-proofing.
Yeah. Thats what I was planning to do. I just couldn't believe Power Commander was actually saying to use one of those plastic wire taps! I was just wondering if anyone followed the line farther back and spliced into there instead of near the harness since there seems to be only about 5 inches of wire to use. Not a lot of wire to mess with..
-George Orwell
CCS Amateur #588
Contributor
Lucky's Avatar
March 6, 2010, 09:04 PM
I did it by the book the first time.. It became a problem and I ended up doing it again. I would also recommend you carefully solder the wires.
2006 Yamaha R6
2008 Zuma YW50
Semper Fi
NESBA #707
CCS AM #991
www.rnrcycles.com VA
www.trianglecycles.com NC/VA
Flickr http://www.flickr.com/photos/27068503@N05/
  Send a message via AIM to Send a message via AIM to Lucky
Super Moderator
Scorpion9R's Avatar
March 7, 2010, 11:31 AM
Yeah..theres not a lot of room to play....Thats why I was wondering if anyone cut into the line anywhere else..
-George Orwell
CCS Amateur #588
Contributor
Lucky's Avatar
March 7, 2010, 01:58 PM
I did not.
2006 Yamaha R6
2008 Zuma YW50
Semper Fi
NESBA #707
CCS AM #991
