» Online Users: 591
1 members and 590 guests
Best way to cleanse radiators?
USSA
ArrrSV's Avatar
Best way to cleanse radiators? - May 2, 2011, 05:17 AM
Should I just use the vinegar solution or are there specialty products out there that do a better job?
I Have Nothing To Contribute.
Chicks are like jobs...all the good ones are taken and they can't pay you enough to do the ones that are available.
Got Any Gwapes?
boomboom929's Avatar
May 2, 2011, 06:56 AM
Motorcycle radiator? Is it clogged with scale or just dirty?
*GODFATHER*
USSA
ArrrSV's Avatar
May 2, 2011, 09:35 AM
Yar. There is some buildup around one of the hoses. Wanted to run some cleaner through for peace of mind.
GET SOME ! ! !
Spyker's Avatar
May 2, 2011, 10:22 AM
What kind of build up? Explain, I'm confused, there is some build up around the connections, or internally, if its around the connections, just get some degreaser and BAM!!!! all done.
Got Any Gwapes?
May 2, 2011, 10:29 AM
I wouldn't get a solvent anywhere near where glycol needs to go, so hold that thought. If you need to clean the inside, you need a salt based cleaner. If it's greasy, use dishwashing liquid on the inside or outside to remove any grease. Some car radiators also cool trans fluid in separate compartments, if the trans fluid leaks into the cooling system, we use Dawn with water to clean it.
*GODFATHER*
USSA
ArrrSV's Avatar
May 2, 2011, 04:50 PM
Ran a mix of distilled white vinegar and distilled water trough it couple times. I was amazed at how much gunk came out. After cleaning it i can it through 2 cycles of distilled water only to flush it out.
T.R.I.T.D.H
TalkofDC's Avatar
May 3, 2011, 10:07 AM
Vinegar and water...that's the way to go.
Your Ad Here
Heist's Avatar
May 5, 2011, 06:01 PM
That's what she said.
