» Online Users: 533
2 members and 531 guests
beatle, Leoallafila
brake pads. Bed-in procedures?
brake pads. Bed-in procedures? - April 14, 2009, 05:50 PM
is this a must-do for all new brakes or just Galfer?
Description
Galfer 1054 Semi-Metallic Carbon Compound: Can be used for sport, touring and commuting applications Works well in wet conditions as well as in cold brake conditions Withstands abrupt temperature changes allowing for a quick feel return NOTE: All Galfer brake pads must be properly "BEDDED-IN" to achieve maximum output and reduce unnecessary rotor wear. Galfer strongly recommends following these BED-IN directions: 1. Clean the brake rotor(s) with thin sand paper and water prior to new pad installation. 2. Towel dry the rotor surface after sanding. 3. Install the new pads and be easy with the brakes for the next 40-50 miles.
Say Jur Oh
Seijirou's Avatar
April 14, 2009, 05:56 PM
Description
De-glazing the rotors is standard if you're not going to have them turned or replaced. Just don't sand in the direction of rotation. Up and down or swirls only.
As far as being easy on the brakes or hard on the brakes, that one is almost as controversial as the engine break-in debate.
Greg "BamBam" Walker
September 11th 2009
You are missed
Godspeed
TPG Bannings: III
April 14, 2009, 06:04 PM
On used rotors I can see that being helpful, I have always prescribed to the hard bed in for brakes on my cars, but I was always replacing rotors at the same time, I just ordered new pads for my bike, I will be doing the hard bed in, don't know if I'm going to clean the rotors first, really depends on how lazy I am that day.
April 14, 2009, 06:07 PM
any specific grit..is 120 ok to use? and you sand just enough to scratch the surface right?
Say Jur Oh
Seijirou's Avatar
April 14, 2009, 06:34 PM
120 is too coarse. I wouldn't hit it with anything rougher than 600. You're basically just scratching the surface.
Think of it like a hone on a cylinder.
September 11th 2009
You are missed
Godspeed
April 14, 2009, 06:55 PM
True.
I use scotchbrite.
Def worth doing. Takes 15 min. I spray mine down with brake cleaner after scuffing.
2008 Honda CRF 450R
Say Jur Oh
Seijirou's Avatar
Originally Posted by SteveZX9 View Post
True.
I use scotchbrite.
Yeah scotchbrite is perfect for the job.
September 11th 2009
You are missed
Godspeed
April 14, 2009, 09:23 PM
dude i totally used a scotchbright (kitchen scratch pad) and hot soapy water on my tank to remove the glue from my decals...man that ish totally scuffed up my paint least i did it evenly
April 14, 2009, 09:46 PM
WD-40 (or kerosine) next time dude. If it's factory paint/color you can even get away with brake cleaner (if you're quick about it).
