» Online Users: 530
1 members and 529 guests
davidcycle
broken swingarm spool mount
slick301's Avatar
broken swingarm spool mount - August 26, 2007, 02:54 PM
A few weeks back I lowsided at the track. Not sure how fast I was going but it was at the double apex right turn on the back of the jefferson track at Summit. I think turn 9 or 10 or 11 but not really sure. Anyways the bike really had no damage whatso ever to the plastics thanks to the shogun cut sliders, they rock by the way. The damage that did occur was broke right rear set, bent right side passenger peg, and my swing arm slider snapped right off at where the mount is on the swing arm. Rear set, passenger pegs and new frame sliders arent a problem to fix/replace. its the swing arm in concerned about.
My question is, How would I go about fixing this problem so I can get another spool on there? On the right side of the swing arm it looks like there was never even a hole to screw in the slider. I've heard of this happening to alot of people after a lowside and was wondering how you guys went about fixing this problem so that you can use your stands again.
Oh this happened on on an 06 GSXR 750. Any help would be appreciated and thanks in advance.
slick301's Avatar
August 26, 2007, 09:24 PM
BUMP...........
ThrustinJZX6's Avatar
August 26, 2007, 10:02 PM
Try drilling a small diameter, shallow pit into the spool thread (smaller than the spool thread itself), then get a damanged screw remover bit. They bite into metal backwards to help removed striped screws.
By drilling the small hole, you give the bit something to grab hold of.
Does that make sense?
slick301's Avatar
August 26, 2007, 10:10 PM
The bolt didnt break off in my swingarm. Right at the bottom of my my swing arm there is a tab that has a hole in it to screw in the spool. The tab is actually a part of the swing arm. The whole tab broke off, so there is no longer a place to srew in the spool. I hope im explaining this right. my swing arm is fine except for the broken tab, My problem is I have no way of using my rear stand now
Bikeless... for now
The New guy's Avatar
August 27, 2007, 06:27 AM
I'd say find a very, very good welder.... or buy yourself a new swing arm
My bike run's on snake oil.... thanks to BG.
'06 ZX-6R in blue
'93 Ninja EX500 (sold)
August 27, 2007, 06:38 AM
Yes it can be welded back on. Do you have the part that broke off? If not one can be made. Or I can drill and tap the swing arm for spools. Contact me and let me know. Pics would help also.
old fat and slow
bambam's Avatar
August 27, 2007, 07:29 AM
the swing arm material is too thin to safely drill and tap for what you want to do. you can buy a replacement tab to have welded back on and then have that done. or you can just convert to a non spooled stand. i had the same thing happen to my 1000 and am working on getting it welded back together soon. if you want to drill the swing arm you will need to use a riv-nut inside the hole instead of tapping it for the spool.
MissS:no now!!!
MissS: I changed my mind
August 27, 2007, 07:31 AM
Hey if quite a few people need replacemnt spool tabs let me know and maybe I should make a whole bunch. Let me know.
