» Online Users: 551
1 members and 550 guests
beatle
check out this spark plug
check out this spark plug - March 26, 2009, 06:12 AM
water??? could it be the slight leak down that still may be possible after my timing was fixed? I'm thinking passing air carries moisture....???
it came out of my 1st cylinder, which was the cylinder in question...and was a major PIA to remove (mainly because I was using a T-handle spark plug remove and had close to zero room to move)
but what could cause rust...corrosion...oxidizing??? notice it's only on one plug.
i was concerned about the state of my spark plugs after running with bad timing for so long...they looked ok for the most part...but I swapped in new ones anyway.
March 26, 2009, 06:34 AM
The photo is so awesome that it's difficult to tell...
You got some water down the hatch is all. All the damage is on the exterior, and the threads and business end look fine.
TPG Bannings: III
March 26, 2009, 06:36 AM
+1 don't worry about it.
still hate you though.
TPG
Jaxxx's Avatar
March 26, 2009, 06:38 AM
...and I thought this saga was over..
2008 - Kawasaki ZX-6R
2007 - Suzuki GSX-R750 (Sold)
1999 - Yamaha R6 (Sold)
TPG
RIP Jeff
  Send a message via AIM to Send a message via AIM to Jaxxx
March 26, 2009, 06:42 AM
hahah thanks!! hands get shakey around 1am lol
March 26, 2009, 10:03 AM
Just because the cams were off does not mean the leakdown test was bad. You still have a problem with that cylinder. The rings might be worn.
Zice's Avatar
March 26, 2009, 10:23 AM
duely noted..appreciate it. I'll do a poor man's leak down and put a drop of oil in the spark plug hole and do a compression test and see if anything is different.
Firebreathing VTwin
Dieder's Avatar
March 26, 2009, 01:04 PM
Stop doing things the "poor way" and just take it to someone with a compressor and a leakdown tester.
MARK DIEDERICH
Love the one you've got...
March 26, 2009, 01:24 PM
Is the plug on the left side (kickstand side) of bike the bike? If so, some bike that have seen rain have this problem. Water runs downhill. Common with older Speed Triples and some GSXR from what I've seen.
March 26, 2009, 01:34 PM
Exactly what I was going to say... at least on the GSXRs. I'd put money that it was pulled off the left side of the bike.
March 26, 2009, 01:35 PM
u know what..that had crossed my mind..but figured the rubber boot on the coils would prevent that. either that or since my air box doesn't seal against the back side of the intake holes...figured water had seeped down there that way. you are correct in the location. the bike has seen everything mother nature can offer.
lol gixrb...no need to bet...i did say it was the 1st cylinder in the OP
I don't like you
nastybastard's Avatar
March 27, 2009, 11:20 AM
That's the problem...you're thinking. Stop thinking, you're only going to confuse yourself even further.
RIP Jeff Vega 10/06/09 You will forever ride on in our hearts
