» Online Users: 493
2 members and 491 guests
GRN96WS6, nootherids
Clutch dragging
Don't ask me,I'm Canadian
C2H5OH's Avatar
Clutch dragging - May 25, 2013, 05:46 PM
I'm picking up an 08 Buell XB9 tomorrow and the clutch drags. When it's in first gear and the clutch lever is pulled in,the bike wants to move forward a bit. The guy selling it says he's tried adjusting the clutch by turning the screw,but it didn't fix it. What else could it be?
Knarly Adventurer
wildjester's Avatar
May 25, 2013, 06:35 PM
Too thick oil viscosity.
Plates are "gummed" up and not fully separating when clutch is in.
Its happened to me on a used R1.
But I only know about Jap bikes... this could be way off on a Buell.
Cure was fresh oil and now plate (cause they were burnt).
2013 Triumph Tiger 800XC
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
C2H5OH's Avatar
May 25, 2013, 06:47 PM
How hard is it to replace the plates?
watch this!...
1is2many's Avatar
May 25, 2013, 07:07 PM
He just turned a screw?
It probably just needs to be adjusted properly.
watch this!...
1is2many's Avatar
May 25, 2013, 07:11 PM
At a minimum there's two places of adjustment on most normal bikes. Once all of the proper
adjustment procedures are done then move on to possible plates and such.
C2H5OH's Avatar
May 25, 2013, 07:20 PM
There's the cable adjustment,then there's the adjustment screw which you turn CCW until it stops,then 1/4 turn CW. He said he did that.
Knarly Adventurer
wildjester's Avatar
May 25, 2013, 08:37 PM
Plates are easy.
Like most oem parts... they are typically the same or more then performance aftermarkets.
I went with a Barnett carbon kevlar kit. About $125... done in an hour or so.
Make sure your shits adjusted right before you spend the money and time... but then again if its been out of adjustment for a while, the plates could be toasted and wouldnt hurt to replace them.
Since I am currently unemployed, I'd be happy to help. I kinda have to stay around the house (baby duty), but if you ride up to Frederick, I will supply tools, knowledge, and drinks.
Let me know
2009 Scrambler SOLD
2007 ZX14 SOLD
2005 R1 SOLD
1999 ZRX SOLD
1996 FZR SOLD
May 25, 2013, 09:19 PM
Could also be that the clutch basket is on too tight. (Happened to me once, it was over-torqued and was basically rubbing metal on metal. Generally a bad thing.)
watch this!...
1is2many's Avatar
May 25, 2013, 09:38 PM
if the plates are bad or burnt then normally they will slip. dragging it normally an adjustment issue or if the plates are sticking, if sticking you can just take them out and clean them and new oil and they should work again for a while.
