» Online Users: 537
3 members and 534 guests
Clutch issue.
Don't ask me,I'm Canadian
C2H5OH's Avatar
Clutch issue. - July 15, 2016, 04:51 PM
Please save the Buell jokes.I just want to ride.
2004 Buell XB12R
Riding to work this morning and shifting started going south in the span of 30 minutes. Had trouble shifting into neutral. Eventually, when I came to a stop, I would have the clutch pulled all the way in and I would have to use the brake from pulling forward and giving it throttle to keep from stalling. At this point the clutch lever had a ton of slack before it would catch. I stopped at a gas station and used the adjuster to take up the slack. Everything was fine for about two blocks and all the slack came back. I parked it and had it towed. There was no fraying of the cable at the lever and the adjuster was very tight. What could be the problem?
KirkRoy's Avatar
July 15, 2016, 05:13 PM
What's happening at the other end of the cable? Do you have a fine adjuster at the lever and a gross adjuster at the clutch?
C2H5OH's Avatar
July 15, 2016, 05:14 PM
The adjuster is mid-cable.
Could this be the problem? Clutch wont adjust correctly, pulled Primary cover, found peices of cover behind adj
C2H5OH's Avatar
July 16, 2016, 03:12 PM
Turned out to be the throwout bearing.
KirkRoy's Avatar
July 16, 2016, 04:20 PM
That doesn't sound so bad although I've never had to replace one...
